zip code is 21784
send me an email here: ngtlight@gmail.com
Assuming you can find an installer be aware that SmartThings isn’t a maintenance free hands off system, well not for me at any rate.
You’d need to be content with the odd item going off-line randomly and an occasional need to re-pair devices to hub. Also dealing with battery changes. Finally depending on your needs and number of devices you may need to tweak routines for seasons or daylight changes.
I’m absolutely not trying to put you off, just be aware you might need to adjust or maintain stuff.
Seriously understated to say “you might need to adjust or maintain stuff”.
You definitely will need to adjust and maintain things! It’s not all that hard, but things do get messed up more easily than anyone would like…
It’s all relative to the individual. The installation isn’t that hard if you’re ok with technology, might be daunting if you’re not. Same goes for ongoing maintenance.
Absolutely correct!
