With my Sensi Smart Thermostat, I see the possibility of triggering a routine by humidity range. What happens when the condition is no longer true? Is there an else statement?
No Else statements. You need a second Routine to trigger when the humidity crosses above/below your range.
A huge problem when attempting to simplify logic–effectively doubling the number of needed routines. Hopefully, someday this will be rectified. ![]()
