Iāve got JasonBSteeleās āZigbee Hue Lux Bulbā DTH for the white bulb, which Iāve had working for many months until the 20.17 update. The colored bulbs had ZigBee RGBW Bulb and were also working fine for several months. I think I did have the issue described by Zach, but they worked OK and that didnāt bother me much. I just tried changing one of the color bulbs to āZLL RGBW Bulbā unfortunately makes no difference - completely unresponsive.
Could my hub have changed Zigbee channel during the last Smartthings firmware update? Iām on channel 14 now, but unfortunately donāt have a record of what it was before.
I think I need to reset the bulbs somehow, but I canāt find the Lutron Connected Bulb Remote for sale anywhere. Iām in the UK, and I think itās gone obsolete anyway? Any advice appreciatedā¦
The Lutron device was never sold in the UK. Thereās an old Philips remote that was sold in UK that you can sometimes find on eBay.
One person said they were able to use one of the newest Phillips dimming switches to reset some hue bulbs that were on non-ZLL channels. I havenāt heard that confirmed by anyone else, but those devices are easy to find and you could try it.
The partial outage might still have applied, so that was good information. Just the posts discussing that āit works in the hue app but not with smartthingsā werenāt relevant to this particular thread, since without a bridge itās not going to work in the hue app. . Easy mistake to make, anyway, since most people are using the bridge. But it can be frustrating to the OP.
Plenty of threads to go around, itās just a matter getting relevant posts together in the right ones.
@WB70 Thanks for the interesting diagram. Iām on 2.4GHz channel 11. A few of my neighbours are in channel 1, but not much I can do about that! All the other zigbee devices I have are working just fine, so I donāt think WiFi interference is the issue with the Hue bulbs not working. I had to rejoin a few after the 20.17 update. All of my other zigbee devices have a reset procedure so it wasnāt much problem.
@JDRoberts Thanks, ordered the Philips Hue switch from Amazon and will have that tomorrow to try. Fingers crossed Iām not throwing good money after bad, but if my bulbs are on Channel 14 like my hub is now - I donāt hold out much hope!
Well, pleasantly surprised!
2 out of 2 of my directly connected Hue bulbs that stopped working after the 20.17 update are now operational again thanks to the Philips Dimmer Switch!
Turn the bulb off and then back on using the mains power switch
Hold the dimmer switch close to the bulb. Hold the on and Off buttons for 10s. The bulb will flash a few times. I kept holding it during the flashing.
After this, turn the bulb off and back on.
Following the sequence above, I was able to add the device as normal again using SmartThings.
Just for fun, after it was rejoined to my hub (zigbee channel 14) I checked to see if I could reset it again using the Hue dimmer switch. At first it didnāt work, but I tried a few things including turning off my Smartthings hub so it wasnāt connected to the bulb. Eventually managed to reset it again, and add it back into Smartthings for a second time.
So - really impressed by the Hue dimmer switch. From what I can tell, itās just as good as the Lutron for resetting Philips Hue bulbs.
Successful on these bulbs:
Philips model: LWB004 (white)
Philips model: LCT010 (coloured)
Eventually you will buy the Hue Bridge, especially when you need to upgrade the Hue Dimmer later on. or you can just buy another dimmer later on with updated firmware.
Not sure if you will be able to identify the version by model and id that it was boxed with.
Having a similar problem. Everything works in the Smartthings appy, yet one Phillips Hue bulb shows as offline. It still turns off and on in the Smartthings appy, yet itās status is offline.
