Also at Walmart
Interesting. I wonder if there’s a new model coming out, or if this is a holiday lighting special. It has been this low before, but not often.
I’m trying to talk myself out of this purchase, but then there’s this use case.
I think I’m doomed…
buy it! buy it! buy it!
Let me help. Spend a little more and go with the Go. Bloom is gen 1 tech and doesn’t dim well, nor does it do colors as nearly well as the Go. Plus you get the built in modes - including candle light - and battery powered operation.
I can always count on my SmartThings community buddies to “help” me spend even more on home automation. Enablers, one and all!
As I was upgrading to Hub v2, I started realizing how much money I have spent over the last couple of years when I first started with SmartThings as a Kickstarter backer. I started out slow, got the hub, a couple of switches, a few multisensors, and a motion sensor. Then every month, I would start adding a device or two like a garage door opener, electronic lock, sirens, thermostat, water sensor, smoke sensor, more switches, more motion sensors, more lights, power meters, voice control with the Amazon Echo, remote controls, and the Harmony Home hub. The list goes on! Now I have my sights on the Phillips Hue but I can’t quite justify the $200 price tag…at least not yet…is it worth it? I’ve added the total cost over the last couple of years, and its a little over $1600.00. My addiction is c…
