RBoy
2
Does this affect all devices using multi channel encapsulation including those which are already paired or only devices that freshly paired? (need to know to be able to test it effectively). I have a variety of devices using 1 to 13 multi channel endpoints.
Well, I know when the update occurs because I have two mirrored hue lights that turn on after the update. This has been happening for the past few updates
0.30.5 is now rolled out, just a few finishing the download. Please test especially if you have Z-Wave devices that were not functioning as expected in 0.30.4 which may have been using endpoints not in the set {0, 1}.
v0.30.5
My Double Switch 2 still working ok with app status updating ok when using app or wall switch.
Single Switch 2 still not updating status in the app but if the app is showing switch is off then switch will turn on. If switch is on and app is showing on then will turn switch off but again no status update in the app.
RBoy
15
So far so good, it’s working with the 8 and 13 endpoint devices. S2 is also working but there was a QR code issue that I reported.
This is great to see. I just applied for the beta program in hopes there would be a fix for the Fibaro FGK-10x. I look forward to being able to get 0.30.5 on my hub.
Looking good here, S2 appears to be working as well, had issues previously with S2 and communicating updates and parameter changes to first switch I changed to S2 during the original V30.3 episode/update (worked on v30.4). Only a Zooz ZSE18, on USB showing zwSwitchStatusLockout -err113:not responding to polls, on hub reboot but appears fine after a z wave repair, contacted Zooz Support. Most Z wave operations appear more responsive now as well.
