HRT4-ZW / SRT321 controlling Z-Wave Device Multichannel 2nd channel (Fiabaro FGS221)
Hi
We have a double relay zwave switch from Fibaro FGS 221
We also have two SRT321 zwave thermostats
Both devices are connected to the smartthings zwave network.
We are trying to set up the association between the first thermostat at S1/O1 of the relay switch, and the second thermostat to the S2/O2 relay switch.
We’ve succsfully set up the association on the first thermostat by putting it into “A” association mode, and flicking the S1 switch 3 times on the relay switch.
However, the problem is with the second thermostat.
Flicking S2 3 times doesn’t seem to do anything, so the only option is to flick S1 which also assocates the 2nd thermostat with O1 instead of the desired O2.
I’ve logged into the web portal edit both the thermostat devices, to try change the userAssocatedDevice to the node associated with O1 and O2. So the first thermostat I’ve set the userAccociated Device to “0A-ep1” and the second thermostat is set to "OA-ep2"
I’ve left them to ensure the wakeup has been called on the devices and would have expected them to be aware of these configuration changes.
However, the second thermostat is still switching the O1 and not the O2
There switch is setup as a general "Z-Wave Device Multichannel"
The thermostats are setup as “SRT321 Thermostat” type using the device handler provided by meavydev
Any ideas on how I can get the second thermostat associating with the O2 on the dual relay switch?
Hi Alan.
Did you succeed?
Thank you.
Hi Alex
I gave up on smart things and moved to HomeAssist with a mix of zwave, zigbee and esphome devices. Havn’t looked back
Does the Z-Wave switch have to be Fibaro?
I have an SRT321 controlling a Secure SSR303 relay exactly as it was designed to do. The SRT321 associates directly with the SSR303.
As a bonus (with the help of community members) i have a working (beta) Edge driver for the SRT321.
As the SRT321 is directly associated with the SSR303, I have not tried writing an Edge driver for it.
Thank you Alan. I am also using HA. :wink:
Did you successfully associate each output of FGS with distinct SRT321 thanks to HA?
