How to trigger a z-wave signal from a 12 V impulse from an intercom
Dear community,
I would like to reach the following feature:
1-) I have a TCP/IP Based intercom , which generates a 12 V signal to open a magnetic door lock to open the door ;
2-) I don’t have a magnetic door lock but a z-wave SCHLAGE connect camelot, which is connected to a smartthings device;
I would like to ask you what would be best device ( kind of relay), which would collect the 12 V impulse and transform it into a signal ( on wired network / Wifi or Z-wave) in order to instruct Smarttthings to open the door lock via z-wave ?
IS there any other solution ?
Thank you,
INTERCOM ( we clikc on push to open ) ==> 12 V DC impulse ===> ( Device ???) ==> instruct Smartthings hub 2 to unlock the door .
Thank you for gyour guidance,
I would use a 12vdc relay, triggered by your 12v impulse. Then on the dry contact side of the relay wire a zwave dry contact sensor, like a gocontrol/linear door sensor, or a Aeotec Z-Wave Dry Contact Sensor. Then just use the rule machine smartapp or something similar to listen for the zwave closure and unlock the door lock. For 12v relays, I just get the generic ones from the local Autozone (car parts store.)
whatever signaling you use (I just thought a few coils around an iron core, close to a Smartsense multisensor, since I have few laying around now but no relays),
I would try to use SmartLighting smartapp in order to have at least a chance for local execution,
otherwise you are depending on internet and ST cloud to drive your door lock (that is too many loose links for my taste).
Thank you for your rply . Taht is very good point indeed not to depend on Internet / Cloud , …Etc.
Is there anyway to send instructions to the Smartthings HUB 2 via Wifi locally say or cabled network ?
