All,
I have a gate that opens when receiving 12vdc. Is there a device that integrates with Smartthings hub that will work for this?
All,
I heard of someone using a thermostat for that use, but I thought that is an expensive solution since the cheapest one I found was $99 + 30 for zwave adapter…
I think the way I’m going to solve it is by simply purchasing a plug in wall outlet. Then a simple AC/DC converter. When I fire on the outlet it will provide power automatically. Thanks for the reply.
If you can solder, you could add a relay and input/output terminals to an arduino and ST Shield.
Evolve LFM-20 Z-Wave Relay Fixture Module
http://www.amazon.com/dp/B006U1O978/%26tag%3Dsmart0f3-20&sa=D&usg=ALhdy2-I8CKkhohR5ht-A5SfARPJRK6_Dg
I just wanted to post an update on here in case anyone needs a solution to this outside of the LFM-20.
I was able to get my front gate to lock/unlock by purchasing the GE 45605 outlet module. I also purchased a 24v 500ma AC/DC inverter on Ebay for $10. My total cost was about $50. From there I simply wired it into my strike lock on my gate which once provided with 24v 500ma of power it unlatches. It is a fail secure gate lock. You can buy them on Ebay for $30.
My next project will be purchasing one of the magnetic door locks on Ebay and wiring this into my safe room!
