I have a small fan heater which when you turn it on it goes to standby. You then have to press on switch once more to start the heater. I have managed to set a routine in Alexa to turn heater on but it only does the first step which means I then have to manually press the on switch again to start the heater. Anybody know how to get around this
Welcome!
This forum is for people who are using the Samsung SmartThings ™ home automation platform, so all of the questions and answers are assumed to be in that context.
Are you currently using smartthings? If so, there are several different ways of accomplishing what you describe.
If you are not using the smartthings ™ home automation platform, it might be better to ask your question in the Alexa help forum. ![]()
Many thanks
