How to replace the SmartApp "Left it Open" to control all the open close sensors in the house with 3 automations and 1 virtual Device
How to replace the SmartApp “Left it Open” to control all the open close sensors in the house with 3 automations and 1 virtual device.
The official Left it Open application required a smartApp configuration for each sensor to be controlled.
@johnconstantelo for your part and I made versions of Left it Open smartApp to control all sensors with a single Left it Open-MultiContact setting, but these will go away with groovy
There are Two options:
    1. Separately control each sensor with 1 routine and 1 virtual sensor:
      You can use Virtual Appliances Mc driver creating a SwitchBoard virtual sensor from 2 to 5 switches that I have on my channel. with which you can do up to 5 routines for 5 sensors with a single virtual device.
      In this way it will send you a personalized and independent message for each open sensor during “x” minutes + another one every “y” minutes
You can make a routine with the door sensor and a virtual device, for example called a reminder:
IF:
  • open sensor open during x minutes
    and
  • virtual switch reminder = Off
THEN
  • virual switch reminder = On and turn Off after “y” minutes
  • Send notification
This will send you a notification when it is open for x minutes
It will send you a notification every y minutes while the door is still open.
In example first notification at 1 minute and every 2 minutes
    1. You can Control all contact sensor you need with 3 Routines and 1 Virtual device Switchboard-2:
      You can do 3 routines with Virtual Appliances Mc driver creating a SwitchBoard 2-Switches virtual device to control all your sensors in the house and it would send you 1 message when one or more sensors are open for “x” minutes and every “y” minutes until all contact sensors are closed.
Example for 4 doors:
Create virtual device SwitchBoard 2-Switches. I renamed as Virtual Letf it Open
Select switchBisrd type: 2 independent switches
You can write the name for every switch, only for detail view.
1st automation:
  • Switch 1 will turn On when any door is open for more than x minutes (in example 1 minute)
  • switch 2 will turn Off when any door is open for more than x minutes (in example 1 minute)
  • You can add precondition: If location mode is Away
  • You can add to send a notification with: Some door is open more than “x” minutes
2nd automation:
IF:
  • Virtual Switch 1 is On and Virtual Switch 2 is Off
Then:
  • Virtual Switch 2 turn On and turn Off “y” minutes after ( in example 2 minutes)
  • Send Notification: Any Door is Open since 1 minute or more
3thd Automation:
IF:
  • All doord are closed
Then:
  • Virtual Switch 1: Turn Off
  • Virtual Switch 2: Turn Off
  • Send Notification: All Doors Closed
The Three automation:
This is the link to my Shared Channel to install Virtual Appliances Mc driver
Now you can also create routines for “Left it Open” more easily with the Timer of Seconds virtual device.
  • Create a Virtual Timer of Seconds device with Aplicaciones Virtuales Mc driver
  • Set the timer to the desired time to resend the door open reminder notification, for example 120 sec
  • Set timer type Permanent Value
  • Set number of loops to value = 0 (infinite loops)
You can also create routines for “Left it Open” with Several door or Windows using Timer of Seconds virtual device.
  • Perform 3 routines:
    • 1st Routine
      IF:
      • Door X is open for 2 minutes
        OR
      • Door Y is open for 2 minutes
        THEN:
      • Timer 120 sec: Restart Timer (push)
    • 2nd Routine
      IF:
    • Condition: Timer 120 sec = On
      THEN:
    • Send notification: Any door X,Y open more than 2 minutes
    • 3rd Routine
      IF:
    • Timer 120 sec = On
      AND
    • Door X is closed
      AND
    • Door Y is closed
      THEN:
    • Timer 120 sec = Off
    • Send notification: All doors X,Y closed
