How to make Xiaomi Aqara Temperature Humidity Sensor to a thermostat with one setpoint?
Hi
I want to use the temperature sensor to controll the heat, using Heatit Z-water in my Smartthings hub
I have managed to control the heat using two automations, one for heat on with one setpoint, and one for heat off useng another setpoint. But its not wery neat. I have to adjust two places if i want to change the temperature. Any solution?
I am a bit stupid, but do You have a suggestion for smartapp and dth, an how do I connect this together?
I believe @RBoy may be able to provide some guidance.
If you’re looking to create a schedule using a temperature sensor and relay like the z-water, try this app (or others like this which also support external sensors)
