So every time I have tried to time limit smart lighting to say only work between 6 P.M. and 7 A.M., as soon as I include the time limitation, the given smart lighting rule simply fails to run.
How can I fix this?
How can I fix this?
your title and your post are confusing to what the actual problem is. Is adding this time limit in the app causing the mobile app to crash? Or is the app working fine, but the automation never runs correctly?
Adding a time limit causes the smartlighting smartapp to stop functioning at all.
So a mobile app issue?
Not sure. Seems like a smartapp issue. Only thing the mobile app is doing here is configuration. I think…
ok, so the automation isn’t working right. Is your location time zone correct in the Web IDE?
Yep, sure is.
