How to Integrate SmartThings with AWS IoT service
Hi,
I have a requirement where Samsung Smartthing Hub that needs to push data to AWS IoT service. Is there a way in which this can be accomplished ?
As far as I know AWS IoT does not work without certificates and there is no way to add that in the groovy script
Really stuck up on this one . Can you please assist
HI, I am also interested in this. Or if this is possible to integrate Samsung SmartThings Hub 3rd Generation to Watson IOT Platform Cloud Service https://console.bluemix.net/catalog/services/internet-of-things-platform
Please answer.
Thank you.
Carlos
Searched and found this topic… Are you wanting to use IoT Things & shadow states to keep track of device state?
You could build a lambda (w/ AWS API Gateway) to update shadow state, then use the JSON Complete API to send events to the lambda…
Alternatively you could run a local HTTP server which published events directly to the AWS IOT MQTT broker (to the special update shadow state topic)… or published to a local mosquitto that published to AWS IOT MQTT… lots of options as I think through this myself.
