New ST Customer here and I am trying to group 4 Cree Connected LED Bulbs so I can turn them ON/OFF/DIM by voice command to Echo Alexa.
I can turn them on and off and dim them with Alexa one by one, but I need to group them and make it easy.
Example: Alexa, turn off the lights in the living room (4 cree bulbs).
In your Echo app, create a new group, give it a unique name. The put those 4 bulbs into it. Then you can either select 1 bulb by name if you only want âherâ to turn on that one, or select the group to turn on all four.
Unlike ST rooms, in Echo you can have the same device in more than one group. So you can have those same 4 bulbs in both the overhead group. In the âlivingroomâ group which has all your livingroom lights in it and also in âhouseâ group that contains every light you have, so at the end of the night you can just say âAlexa turn off the houseâ and she makes sure all your lights are off.
In Echo app, NOT it the ST app. Open your Echo app on your phone, or login to echo.amazon.com. Select your echo and then settings, connected home, groups, new group
In ST a device can only be in 1 room. In Echo you can have a device in multiple groups.
So IN ST you assign a bulb to Living room and that is where is stays.
However in Echo The same bulbs in the âoverhead lightâ group can also be in the " Living room" group and also in the " house" group. Which is exactly what I said before.
Ah I see, youâre referring to rooms as groups, I was hoping there was a function I had missed so that for example I could group say, four GE Links in the can lights in the master bedroom, I guess not!
How did you get your Cree Connected bulbs to be recognized by the Echo? Iâve done the standard âConnected Homeâ setup but it fails to recognize only my bulbs.
Did you go into the Amazon Echo app in ST and enable them to be seen by Echo, before you had Echo discover devices ? I always forget that step when adding new devices. Add to ST, add to Echo app in ST, then discover with Echo.
