Is it possible to trigger a script to run on a Raspberry Pi?
I currently have RF switches to turn on/off plugs using my Pi + Tellstick. Would like to connect it somehow to my new Smartthings hub and then have Amazon echo to turn things on/off.
I am not sure if this is exactly what you want but I have some blinds controlled by some scripts in my raspberry pi. I set up a small web server in my pi so I could communicate with them. Then a device handler talks to the corresponding python web server. It works very well in my setup.
Welcome! Many people are using a raspberry pi with SmartThings in many different ways.
It’s often the basis for integrations like smartthings to Lutron or smartthings to light wave RF. You’ll find a lot of the project reports on those in the project section. You can use the quick browse list in the community – created wiki and look at lighting projects, I think most of them are there. And there are a couple of different device type handlers on the dth list under miscellaneous.
Hi @jrhbcn where do i start as I am newbie to all this. Can you send me some links of what to get and how to put things together?
Thank you in advance.
