Hi. I’m new to home automation. I recently purchased a Amazon Echo and a Smartthings hub. I already had a Nest thermostat. Is there a good way to connect these devices. If like Smartthings to control all the home automation if possible. Thanks!
Check out Nest Manager. Being new you will have to get used to installing custom code in the smartthings IDE, but its easy and there if good documentation on now to do it in Nest Manager docs.
