At the GitHub site, at the top level, there is a pdf file " Cloud TP-Link to SmartThing Installation.pdf" providing explicit step-by-step instructions including the file identifications.
After entering my TP-Link username/password and selecting āInitial Installā in the TP-Link Device Service Manager (SmartThings phone app) I click āNextā and am presented with a blank page that never updates. No error is displayed. It is just blank. If I click āSaveā I get an error of ābad stateā. Iāve gone through the installation instructions several times with the same results. My device is a TP Link HS110. I used the TPLink Cloud Connect V2.groovy file for the smart app and the (Cloud) TP-Link EnergyMonitor Plug.groovy file for the device handler. As far as I can tell Iāve done everything correctly. Not sure what the issue is.
I have never seen that. I will research and answer on my thread at: TP-Link Smart Wi-Fi Light Switch
This is the proper thread.
Hiya, this may be a dumb question, but I canāt install Service Manager? I added it in IDE but canāt find it on phone app as it does not have a category called āSmartthings Labsā.
Iām fairly new to ST and donāt know much about coding. So far Iāve installed the device handler (I have three LB110s to connect). in IDE added the coding to āmy smartappsā, saved and published it. But I canāt find it to install on my mobile phone.
Was there anything I did incorrectly, or is there anything else I need to do?
Many thanks
Edited: Tried again this time it worked (somehow). Very weird. I signed up IDE and followed instructions for webCoRE on one computer (computer A), then a couple of days later followed the āHOW TOā for TP link bulbs on a different computer (computer B), on computer B I couldnāt even see my webCoRE in āmy smartappsā but can see āmy locationā OK. canāt see my hub or any devices. I added device handler and service manager in IDE on Computer B, not seeing it at all on mobile app. This morning I opened IDE again on computer A, now I can see my hub, my devices and webCoRE, but lost all the device handlers I added last nightā¦
Iām using the same Samsung account throughout.
Now I can see Cloud Connect on my phone, but when trying to install it I had āunexpected errorā. Iāll try again when I get back home as Iām currently not within the same wifi network with the bulb Iām trying to connect.
Iām having the same issue. Iāve been using the bulbs and switches for almost a year with no issue after integrating with SmartThings. I just tried to add a new HS-100 and HS-110 and it fails every time.
Have you tried uninstall and then re-install the smart app and service managers. I had to make some changes and the old files are not compatible.
It wonāt let me delete the old SmartApp. Iāve read some posts online about where to delete it on IDE, but I continue to get an error. I created a ticket for Samsung support to see if they can help me delete the app. Thanks for your response.
To delete, all associated devices need to be deleted. You may already know this, but just to confirm.
Thanks Dave. Actually I did not know that. It was talking about users. I wasnāt sure how everything was linked together. I was able to delete the devices and then the old SmartApp. Iāve now added the new SmartApp and device handlers and everything is up and working, including the HS100 that previously wouldnāt add. Thanks again for your help!
Hey Dave.
I originally had my TP-Link Kasa HS110 working with SmartThings but something happened and I stoped using the outlet. Anyway, I wanted to start using it again and cleared out everything associated with it in IDE. I added the Service Manager to the IDE My Smart Apps and added the SmartApp on my device. I have successfully added my credentials and selected Initial Install - The TP-Link Device show with the correct name and I click done and then get an error - when I reviewed the error log I have the following:
******-cf22-4a83-93b9-8a7e966caf5d 8:44:36 PM: error physicalgraph.app.exception.UnknownDeviceTypeException: Device type ā(Cloud) TP-Link EnergyMonitor Plugā in namespace ādavegutā not found. @line 206 (doCall)
Do I need to add in the device handler as well? I did have it set that way initially, but then removed the device handler and got the same error.
What am I doing wrong?
Thanks,
EP
You need to add the device handler below. This is specific to the HS110.
