joelw135
(Joel W)
January 7, 2017, 7:47pm
#1
Has anyone got these to work TP-Link Smart Plug w/ Energy Monitoring, No Hub Required, Wi-Fi, Works with Alexa, Control your Devices from Anywhere (HS110)?
This works for the HS100, I’m not sure about the HS110 but might be worth a shot.
This how-to was originally posted inside of this thread. I am starting a separate thread to gain additional visibility for anyone who is looking.
Special thanks to @dbej for creating the DTH and code for this, this is all his work. I’m just the messenger
Note: This setup requires the use of an internal “gateway” server/PC that receives commands from the SmartThings hub and translates/forwards them on to your TP-Link HS-100 outlets, so it’s more complex than the typical smartapp & DTH type integration. The instructions below are specific to a Windows environment, but several community members have been able to accomplish the same integration using a Raspberry Pi or similar. While @dbej used Docker to get this up and running, I am using a node.js command prompt instead, so keep in m…
joelw135
(Joel W)
January 8, 2017, 4:11am
#3
Thanks, I am not sure I want to buy a Pie 3 B just to do this. Can it be run on a Mac?
I’m not sure. Check if node is available for Mac.
joelw135
(Joel W)
January 8, 2017, 4:17am
#5
I will do that. Another thing on my list.
