my mission is to say ‘alexa play playlist’
and a spotify playlist plays through my samsung soundbar
i have:
ST hub
harmony hub
echo (on its way)
i dont want o just play through echo as its a bit of a waste of my soundbar
come on people… we can figure this out!
@karl_harris Karl which Echo do you have? I have an original one plus a Dot. The dot is better than the original version in that it has both a 3.5mm jack and it will connect via bluetooth to a speaker. In my flat in Spain I say “Alex play favourites” and my playlist plays over my LG H7 speaker.
I use both.
The Echo has pretty good sound from it and end up using that quite a bit. Doesn’t over fill the room with sound, like the soundbar does.
I use my Vizio sound bar with smartcast and control it from my phone.
RIght now I don’t think you can trigger a playlist from Echo to play on another device.
I am a vinyl fan - no ST integration there I am afraid - but the sound quality from the Amazon Echo is pretty good and I can live with it for background noise.
@JDRoberts I think Amazon may have under estimated the popularity of the Dot. Apart from the fact it was cheaper, the ability to pump your audio over to a better quality speaker made it a no brainer for many people.
