Hi @lmullineux
Unfortunately it’s not available on GitHub but I can share the code here. This is src/init.lua:
local capabilities = require "st.capabilities"
local ZigbeeDriver = require "st.zigbee"
local defaults = require "st.zigbee.defaults"
local log = require "log"
local utils = require "st.utils"
log.info("Here we are")
local zigbee_button_driver_template = {
supported_capabilities = {
capabilities.battery,
capabilities.button,
sub_drivers = {
require("tradfri-on-off-button"),
require("tradfri-remote-control")
defaults.register_for_default_handlers(zigbee_button_driver_template, zigbee_button_driver_template.supported_capabilities)
local driver = ZigbeeDriver("zigbee-button", zigbee_button_driver_template)
driver:run()
and this is src/tradfri-remote-control/init.lua:
local zcl_clusters = require "st.zigbee.zcl.clusters"
local OnOff = zcl_clusters.OnOff
local Level = zcl_clusters.Level
local Scenes = zcl_clusters.Scenes
local PowerConfiguration = zcl_clusters.PowerConfiguration
local constants = require "st.zigbee.constants"
local messages = require "st.zigbee.messages"
local mgmt_bind_req = require "st.zigbee.zdo.mgmt_bind_request"
local mgmt_bind_resp = require "st.zigbee.zdo.mgmt_bind_response"
local zdo_messages = require "st.zigbee.zdo"
local device_management = require "st.zigbee.device_management"
local battery_defaults = require "st.zigbee.defaults.battery_defaults"
local is_tradfri_remote_control = function(opts, driver, device)
local is_tradfri_on_off = device:get_manufacturer() == "IKEA of Sweden" and device:get_model() == "TRADFRI remote control"
log.debug("Is Tradfri Remote Control: " .. tostring(is_tradfri_on_off))
return is_tradfri_on_off
end
function toggle_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri TOGGLE")
device:emit_event_for_endpoint(5, capabilities.button.button.pushed({ state_change = true }))
device:emit_event(capabilities.button.button.pushed({ state_change = true }))
end
function pushed_up_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri pushed UP")
device:emit_event_for_endpoint(1, capabilities.button.button.pushed({ state_change = true }))
end
function held_up_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri held UP")
device:emit_event_for_endpoint(1, capabilities.button.button.held({ state_change = true }))
device:emit_event(capabilities.button.button.held({ state_change = true }))
end
function pushed_down_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri pushed DOWN")
device:emit_event_for_endpoint(2, capabilities.button.button.pushed({ state_change = true }))
end
function held_down_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri held DOWN")
device:emit_event_for_endpoint(2, capabilities.button.button.held({ state_change = true }))
end
local function left_right_pushed_handler(driver, device, zb_rx)
log.debug("Handling Tradfri left/right button PUSHED, value: " .. zb_rx.body.zcl_body.body_bytes:byte(1))
local button_number = zb_rx.body.zcl_body.body_bytes:byte(1) == 0 and 4 or 3
device:emit_event_for_endpoint(button_number, capabilities.button.button.pushed({ state_change = true }))
end
local function left_right_held_handler(driver, device, zb_rx)
log.debug("Handling Tradfri left/right button HELD, value: " .. zb_rx.body.zcl_body.body_bytes:byte(1))
local button_number = zb_rx.body.zcl_body.body_bytes:byte(1) == 1 and 3 or 4
device:emit_event_for_endpoint(button_number, capabilities.button.button.held({ state_change = true }))
end
function not_held_handler(driver, device, value, zb_rx)
log.debug("Handling Tradfri not held. Nothing to do.")
end
local function component_to_endpoint(device, component_id)
local ep_num = component_id:match("button(%d)")
return { ep_num and tonumber(ep_num) } or {}
end
local function endpoint_to_component(device, ep)
local button_comp = string.format("button%d", ep)
if device.profile.components[button_comp] ~= nil then
return button_comp
else
return "main"
end
end
local function device_configure(driver, device, event, args)
log.debug("Configuring device")
local addr_header = messages.AddressHeader(
constants.HUB.ADDR,
constants.HUB.ENDPOINT,
device:get_short_address(),
device.fingerprinted_endpoint_id,
constants.ZDO_PROFILE_ID,
mgmt_bind_req.BINDING_TABLE_REQUEST_CLUSTER_ID
local binding_table_req = mgmt_bind_req.MgmtBindRequest(0)
local message_body = zdo_messages.ZdoMessageBody({
zdo_body = binding_table_req
local binding_table_cmd = messages.ZigbeeMessageTx({
address_header = addr_header,
body = message_body
device:send(binding_table_cmd)
device_management.configure(driver, device)
end
local function device_added(driver, device)
log.info("Device added handler")
device:refresh() -- for battery state. Needed?
end
local function device_init(driver, device, event, args)
device:set_component_to_endpoint_fn(component_to_endpoint)
device:set_endpoint_to_component_fn(endpoint_to_component)
device:emit_event(capabilities.button.numberOfButtons(5))
device:emit_event(capabilities.button.supportedButtonValues({'pushed', 'held'}))
device:emit_event(capabilities.button.button.pushed())
for i = 1, 5 do
device:emit_event_for_endpoint(i, capabilities.button.numberOfButtons(1))
device:emit_event_for_endpoint(i, capabilities.button.supportedButtonValues(i ~= 5 and {'pushed', 'held'} or {'pushed'}))
device:emit_event_for_endpoint(i, capabilities.button.button.pushed())
end
end
local function battery_perc_attr_handler(driver, device, value, zb_rx)
local perc = value.value -- Some Tradfri devices present value in percentage without dividing by 2, is it correct for Remote Control?
device:emit_event(capabilities.battery.battery(math.min(perc, 100)))
end
local function zdo_binding_table_handler(driver, device, zb_rx)
log.debug("Received ZDO binding table message")
for _, binding_table in pairs(zb_rx.body.zdo_body.binding_table_entries) do
if binding_table.dest_addr_mode.value == binding_table.DEST_ADDR_MODE_SHORT then
local group = binding_table.dest_addr.value
log.debug("Adding hub to group: " .. tostring(group))
driver:add_hub_to_zigbee_group(group)
end
end
end
local tradfri_remote_control = {
NAME = "IKEA Tradfri Remote Control",
lifecycle_handlers = {
init = device_init,
added = device_added,
doConfigure = device_configure
zigbee_handlers = {
attr = {
[PowerConfiguration.ID] = {
[PowerConfiguration.attributes.BatteryPercentageRemaining.ID] = battery_perc_attr_handler
cluster = {
[OnOff.ID] = {
[OnOff.commands.Toggle.ID] = toggle_handler
[Level.ID] = {
[Level.commands.StepWithOnOff.ID] = pushed_up_handler,
[Level.commands.MoveWithOnOff.ID] = held_up_handler,
[Level.commands.StopWithOnOff.ID] = not_held_handler,
[Level.commands.Step.ID] = pushed_down_handler,
[Level.commands.Move.ID] = held_down_handler,
[Level.commands.Stop.ID] = not_held_handler
[Scenes.ID] = {
[0x07] = left_right_pushed_handler,
[0x08] = left_right_held_handler,
[0x09] = not_held_handler
zdo = {
[mgmt_bind_resp.MGMT_BIND_RESPONSE] = zdo_binding_table_handler
can_handle = is_tradfri_remote_control
return tradfri_remote_control
Sorry for the code quality and many logs but they were very helpful during development.
