This is the Error. Huge might be the wrong word
Org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed: script_dth_metadata_1a935559_c6dc_4ea5_aa4e_5757f6b18738: 1: unexpected token: 2 @ line 1, column 1. 2) { multiAttributeTile(name:“switch”, type: “generic”, width: 6, height: 4, canChangeIcon: true){ tileAttribute (“device.switch”, key: “PRIMARY_CONTROL”) { attributeState “on”, label: ‘{name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc" attributeState "off", label: '{name}’, action: “switch.on”, icon: “st.switches.switch.off”, backgroundColor: “#ffffff” } tileAttribute (“device.acceleration”, key: “SECONDARY_CONTROL”) { attributeState “inactive”, label:‘INACTIVE’ attributeState “active”, label:‘ACTIVE’ } } standardTile(“refresh”, “device.refresh”, width: 2, height: 2) { state “refresh”, label:‘Refresh’, action: “refresh”, icon:“st.secondary.refresh-icon” } standardTile(“reset”, “device.reset”, width: 2, height: 2) { state “refresh”, label:‘Reset’, action: “reset”, icon:“st.secondary.refresh-icon” } valueTile(“energy”, “device.energy”, width: 2, height: 2) { state “energy”, label:’{currentValue} kWh', backgroundColor: "#cccccc" } valueTile("power", "device.power", width: 2, height: 2) { state "power", label:'{currentValue} W’, backgroundColor: “#cccccc” } valueTile(“voltage”, “device.voltage”, width: 2, height: 2) { state “voltage”, label:’{currentValue} V', backgroundColor: "#cccccc" } valueTile("current", "device.current", width: 2, height: 2) { state "current", label:'{currentValue} A’, backgroundColor: “#cccccc” } valueTile(“history”, “device.history”, decoration:“flat”,width: 6, height: 3) { state “history”, label:’{currentValue}' } valueTile("firmwareVersion", "device.firmwareVersion", decoration:"flat", width:3, height: 1) { state "firmwareVersion", label:'Firmware {currentValue}’ } main “switch” details([“switch”, “power”, “energy”, “refresh”, “voltage”, “current”, “reset”, “history”, “firmwareVersion”]) } } def clientVersion() { return “1.1” } private getOptionsInput(param) { if (param.prefName) { input “{param.prefName}", "enum", title: "{param.name}:”, defaultValue: “{param.val}", required: false, displayDuringSetup: true, options: param.options?.collect { name, val -> name } } } private getBoolInput(name, title, defaultVal) { input "{name}”, “bool”, title: “{title}?", defaultValue: defaultVal, required: false } // Meters private getMeterEnergy() { return getMeterMap("energy", 0, "kWh", null, settings?.displayEnergy != false) } private getMeterPower() { return getMeterMap("power", 2, "W", 2000, settings?.displayPower != false) } private getMeterVoltage() { return getMeterMap("voltage", 4, "V", 150, settings?.displayVoltage != false) } private getMeterCurrent() { return getMeterMap("current", 5, "A", 18, settings?.displayCurrent != false) } private getMeterMap(name, scale, unit, limit, displayed) { return [name:name, scale:scale, unit:unit, limit: limit, displayed:displayed] } def updated() { if (!isDuplicateCommand(state.lastUpdated, 3000)) { state.lastUpdated = new Date().time def cmds = configure() return cmds ? response(cmds) : [] } } def configure() { def result = [] updateHealthCheckInterval() def cmds = [] if (!device.currentValue("firmwareVersion")) { cmds << versionGetCmd() } configParams.each { param -> cmds += updateConfigVal(param) } result += delayBetweenCmds(cmds) if (!getAttrVal("energyTime")) { result += reset() } else { result += refresh() } return result } private updateConfigVal(param) { def cmds = [] if (hasPendingChange(param)) { def oldVal = getParamStoredIntVal(param) def newVal = getParamIntVal(param) logTrace "{param.name}(#{param.num}): changing {getParamStoredIntVal(param)} to {newVal}" cmds << configSetCmd(param, newVal) cmds << configGetCmd(param) } return cmds } private hasPendingChange(param) { return (getParamIntVal(param) != getParamStoredIntVal(param)) } void updateHealthCheckInterval() { def minReportingInterval = minimumReportingInterval if (state.minReportingInterval != minReportingInterval) { state.minReportingInterval = minReportingInterval // Set the Health Check interval so that it can be skipped twice plus 5 minutes. def checkInterval = ((minReportingInterval * 2) + (5 * 60)) def eventMap = createEventMap("checkInterval", checkInterval, false) eventMap.data = [protocol: "zwave", hubHardwareId: device.hub.hardwareID] sendEvent(eventMap) } } def ping() { logDebug "Pinging device because it has not checked in" return [switchBinaryGetCmd()] } def on() { logTrace "Turning On" return delayBetweenCmds([ switchBinarySetCmd(0xFF), switchBinaryGetCmd() ]) } def off() { if (disableSwitchSetting) { logTrace "Switch is disabled" } else { logTrace "Turning Off" return delayBetweenCmds([ switchBinarySetCmd(0x00), switchBinaryGetCmd() ]) } } def refresh() { logTrace "Refreshing" return delayBetweenCmds([ switchBinaryGetCmd(), meterGetCmd(meterEnergy), meterGetCmd(meterPower), meterGetCmd(meterVoltage), meterGetCmd(meterCurrent) ]) } def reset() { logTrace "Resetting" ["power", "voltage", "current"].each { sendEvent(createEventMap("{it}Low”, getAttrVal(it), false)) sendEvent(createEventMap("${it}High", getAttrVal(it), false)) } sendEvent(createEventMap(“energyTime”, new Date().time, false)) def result = result << meterResetCmd() result += refresh() return result } private meterGetCmd(meter) { return secureCmd(zwave.meterV3.meterGet(scale: meter.scale)) } private meterResetCmd() { return secureCmd(zwave.meterV3.meterReset()) } private versionGetCmd() { return secureCmd(zwave.versionV1.versionGet()) } private switchBinaryGetCmd() { return secureCmd(zwave.switchBinaryV1.switchBinaryGet()) } private switchBinarySetCmd(val) { return secureCmd(zwave.switchBinaryV1.switchBinarySet(switchValue: val)) } private configSetCmd(param, val) { return secureCmd(zwave.configurationV2.configurationSet(parameterNumber: param.num, size: param.size, scaledConfigurationValue: val)) } private configGetCmd(param) { return secureCmd(zwave.configurationV2.configurationGet(parameterNumber: param.num)) } private secureCmd(cmd) { if (zwaveInfo?.zw?.contains(“s”) || (“0x98” in device.rawDescription?.split(" “))) { return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format() } else { return cmd.format() } } private delayBetweenCmds(cmds, delay=500) { return cmds ? delayBetween(cmds, delay) : } def parse(String description) { def result = def cmd = zwave.parse(description, commandClassVersions) if (cmd) { result += zwaveEvent(cmd) } else { log.warn “Unable to parse: $description” } if (!isDuplicateCommand(state.lastCheckinTime, 60000)) { state.lastCheckinTime = new Date().time result << createEvent(createEventMap(“lastCheckin”, convertToLocalTimeString(new Date()), false)) } return result } def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) { def encapsulatedCmd = cmd.encapsulatedCommand(commandClassVersions) def result = if (encapsulatedCmd) { result += zwaveEvent(encapsulatedCmd) } else { log.warn “Unable to extract encapsulated cmd from cmd" } return result } private getCommandClassVersions() { [ 0x20: 1, // Basic 0x25: 1, // Switch Binary 0x27: 1, // All Switch 0x2B: 1, // Scene Activation 0x2C: 1, // Scene Actuator Configuration 0x32: 3, // Meter v4 0x59: 1, // AssociationGrpInfo 0x5A: 1, // DeviceResetLocally 0x5E: 2, // ZwaveplusInfo 0x70: 2, // Configuration 0x72: 2, // ManufacturerSpecific 0x73: 1, // Powerlevel 0x7A: 2, // Firmware Update Md (3) 0x85: 2, // Association 0x86: 1, // Version (2) 0x98: 1 // Security ] } def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) { def val = cmd.scaledConfigurationValue def configParam = configParams.find { param -> param.num == cmd.parameterNumber } if (configParam) { def name = configParam.options?.find { it.value == val}?.key logDebug "{configParam.name}(#{configParam.num}) = {name != null ? name : val} ({val})" state["configVal{cmd.parameterNumber}”] = val } else { logDebug “Parameter {cmd.parameterNumber} = {val}” } return } def zwaveEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd) { logTrace “VersionReport: {cmd}" def version = "{cmd.applicationVersion}.{cmd.applicationSubVersion}" if (version != device.currentValue("firmwareVersion")) { logDebug "Firmware: {version}” sendEvent(name: “firmwareVersion”, value: version, displayed:false) } return } def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) { logTrace “SwitchBinaryReport: {cmd}" def result = [] result << createSwitchEvent(cmd.value, "digital") return result } def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) { logTrace "BasicReport: {cmd}” def result = result << createSwitchEvent(cmd.value, “physical”) return result } private createSwitchEvent(value, type) { def eventVal = (value == 0xFF) ? “on” : “off” def map = createEventMap(“switch”, eventVal, null, “Switch is ${eventVal}”) map.type = type return createEvent(map) } def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) { logTrace “MeterReport: $cmd” def result = def val = roundTwoPlaces(cmd.scaledMeterValue) def meter switch (cmd.scale) { case meterEnergy.scale: meter = meterEnergy break case meterPower.scale: createAccelerationEvent(val) meter = meterPower break case meterVoltage.scale: meter = meterVoltage break case meterCurrent.scale: meter = meterCurrent break default: logDebug “Unknown Meter Scale: cmd" } if (meter?.limit && val > meter.limit) { log.warn "Ignored {meter.name} value {val}{meter.unit} because the highest possible value is {meter.limit}{meter.unit}.” } else if (meter?.name && getAttrVal(”{[meter.name](http://meter.name)}") != val) { result << createEvent(createEventMap([meter.name](http://meter.name), val, meter.displayed, null, meter.unit)) if ([meter.name](http://meter.name) == [meterEnergy.name](http://meterEnergy.name)) { result += createEnergyEvents(val) } else { result += createHighLowEvents(meter, val) } runIn(5, refreshHistory) } return result } private createAccelerationEvent(val) { def deviceActive = (device.currentValue("acceleration") == "active") if (val > inactivePowerSetting && !deviceActive) { sendEvent(name:"acceleration", value:"active", displayed:false) } else if (val <= inactivePowerSetting && deviceActive){ sendEvent(name:"acceleration", value:"inactive", displayed:false) } } private createHighLowEvents(meter, val) { def result = [] def highLowNames = [] def highName = "{meter.name}High" def lowName = “${meter.name}Low” if (!getAttrVal(highName) || val > getAttrVal(highName)) { highLowNames << highName } if (!getAttrVal(lowName) || meter.value < getAttrVal(lowName)) { highLowNames << lowName } highLowNames.each { result << createEvent(createEventMap("it", val, false, null, meter.unit)) } return result } private createEnergyEvents(val) { def result = [] def cost = "\${roundTwoPlaces(val * energyPriceSetting)}" if (getAttrVal(“energyCost”) != cost) { result << createEvent(createEventMap(“energyCost”, cost, false)) } result << createEvent(createEventMap(“energyDuration”, calculateEnergyDuration(), false)) return result } private calculateEnergyDuration() { def energyTimeMS = getAttrVal(“energyTime”) if (!energyTimeMS) { return “Unknown” } else { def duration = roundTwoPlaces((new Date().time - energyTimeMS) / 60000) if (duration >= (24 * 60)) { return getFormattedDuration(duration, (24 * 60), “Day”) } else if (duration >= 60) { return getFormattedDuration(duration, 60, “Hour”) } else { return getFormattedDuration(duration, 0, “Minute”) } } } private getFormattedDuration(duration, divisor, name) { if (divisor) { duration = roundTwoPlaces(duration / divisor) } return “{duration} {name}{duration == 1 ? '' : 's'}" } def refreshHistory() { def history = "" def items = [:] items["energyDuration"] = "Energy - Duration" items["energyCost"] = "Energy - Cost" ["power", "voltage", "current"].each { items["{it}Low”] = “{it.capitalize()} - Low" items["{it}High”] = “{it.capitalize()} - High" } items.each { attrName, caption -> def attr = device.currentState("{attrName}”) def val = attr?.value ?: “” def unit = attr?.unit ?: “” history += “{caption}: {val} ${unit}\n” } sendEvent(createEventMap(“history”, history, false)) } def zwaveEvent(physicalgraph.zwave.Command cmd) { logDebug “Unhandled zwaveEvent: cmd" return [] } // Configuration Parameters private getConfigParams() { return [ instantPowerValuesParam, instantPowerFrequencyParam, ledIndicatorParam, ] } private getInstantPowerValuesParam() { return createConfigParamMap(101, "Instantaneous Power Report Values", 4, ["Current":8, "kWh/Watt":9, "Current/Watt":10, "Current/Watt/kWh":11, "Current/Voltage":12, "Current/Voltage/kWh":13, "Current/Voltage/Watt":14, "All{defaultOptionSuffix}”:15], “instantPowerValues”) } private getinstantPowerFrequencyParam() { return createConfigParamMap(111, “Instantaneous Power Report Frequency”, 4, [“10 Seconds”:10, “30 Seconds${defaultOptionSuffix}”:30, “1 Minute”:60, “2 Minutes”:120, “5 Minutes”:300], “instantPowerFrequency”) } private getLedIndicatorParam() { return createConfigParamMap(83, “LED Power Indicator”, 1, [“Follow the status of load (Energy mode){defaultOptionSuffix}":0, "Follow the status (on/off) of load. Red LED turns off after 5 sec if no change (Momentary indicate mode)":1], "ledIndicator") } private getParamStoredIntVal(param) { return state["configVal{param.num}”] } private getParamIntVal(param) { return param.options ? convertOptionSettingToInt(param.options, param.val) : param.val } private createConfigParamMap(num, name, size, options, prefName, val=null) { if (val == null) { val = (settings?."{prefName}" ?: findDefaultOptionName(options)) } return [ num: num, name: name, size: size, options: options, prefName: prefName, val: val ] } // Settings private getEnergyPriceSetting() { return safeToDec(settings?.energyPrice, 0.12) } private getInactivePowerSetting() { return safeToInt(settings?.inactivePower, 0) } private getDebugOutputSetting() { return settings?.debugOutput != false } private getTraceOutputSetting() { return settings?.traceOutput != false } private getDisableSwitchSetting() { return settings?.disableSwitch != false } private getMinimumReportingInterval() { def minVal = (60 * 60 * 24 * 7) return minVal } private getIntervalOptions(defaultVal=null, zeroName=null) { def options = [:] if (zeroName) { options["{zeroName}"] = 0 } options << getIntervalOptionsRange(“Second”, 1, [5,10,15,30,45]) options << getIntervalOptionsRange(“Minute”, 60, [1,2,3,4,5,10,15,30,45]) options << getIntervalOptionsRange(“Hour”, (60 * 60), [1,2,3,6,9,12,18]) options << getIntervalOptionsRange(“Day”, (60 * 60 * 24), [1,3,5]) options << getIntervalOptionsRange(“Week”, (60 * 60 * 24 * 7), [1,2]) return setDefaultOption(options, defaultVal) } private getIntervalOptionsRange(name, multiplier, range) { def options = [:] range?.each { options["{it} {name}{it == 1 ? '' : 's'}"] = (it * multiplier) } return options } private getPowerValueOptions() { def options = [:] [0,1,2,3,4,5,10,25,50,75,100,150,200,250,300,400,500,750,1000,1250,1500,1750,2000,2500,3000,3500,4000,4500,5000,6000,7000,8000,9000,10000,12500,15000].each { if (it == 0) { options["No Reports"] = it } else { options["{it} Watts"] = it } } return setDefaultOption(options, 50) } private getPercentageOptions(defaultVal=null, zeroName=null) { def options = [:] if (zeroName) { options["{zeroName}"] = 0 } for (int i = 1; i <= 5; i += 1) { options["{i}%"] = i } for (int i = 10; i <= 100; i += 5) { options["{i}%"] = i } return setDefaultOption(options, defaultVal) } private convertOptionSettingToInt(options, settingVal) { return safeToInt(options?.find { name, val -> "{settingVal}" == name }?.value, 0) } private setDefaultOption(options, defaultVal) { def name = options.find { key, val -> val == defaultVal }?.key if (name != null) { return changeOptionName(options, defaultVal, “{name}{defaultOptionSuffix}”) } else { return options } } private changeOptionName(options, optionVal, newName) { def result = [:] options?.each { name, val -> if (val == optionVal) { name = “{newName}" } result["{name}”] = val } return result } private findDefaultOptionName(options) { def option = options?.find { name, val -> name?.contains("{defaultOptionSuffix}") } return option?.key ?: "" } private getDefaultOptionSuffix() { return " (Default)" } private createEventMap(name, value, displayed=null, desc=null, unit=null) { desc = desc ?: "{name} is {value}" def eventMap = [ name: name, value: value, // isStateChange: true, displayed: (displayed == null ? ("{getAttrVal(name)}" != “{value}") : displayed) ] if (unit) { eventMap.unit = unit desc = "{desc} {unit}" } if (desc && eventMap.displayed) { logDebug desc eventMap.descriptionText = "{device.displayName} - {desc}" } else { logTrace "Creating Event: {eventMap}” } return eventMap } private getAttrVal(attrName) { try { return device?.currentValue("${attrName}") } catch (ex) { logTrace “ex" return null } } private safeToInt(val, defaultVal=0) { return "{val}”?.isInteger() ? “{val}".toInteger() : defaultVal } private safeToDec(val, defaultVal=0) { return "{val}”?.isBigDecimal() ? “${val}”.toBigDecimal() : defaultVal } private roundTwoPlaces(val) { return Math.round(safeToDec(val) * 100) / 100 } private convertToLocalTimeString(dt) { def timeZoneId = location?.timeZone?.ID if (timeZoneId) { return dt.format(“MM/dd/yyyy hh:mm:ss a”, TimeZone.getTimeZone(timeZoneId)) } else { return “$dt” } } private isDuplicateCommand(lastExecuted, allowedMil) { !lastExecuted ? false : (lastExecuted + allowedMil > new Date().time) } private logDebug(msg) { if (debugOutputSetting) { log.debug “$msg” } } private logTrace(msg) { if (traceOutputSetting) { log.trace “$msg” } } ^ 1 error
