Model numbers:
Model A1625 w/tvOS 11.2.1
4th generation
Can we get a Smartthings employee to chime in on this thread? Any interest here to enable this for users? If getting commercial support is difficult through MFI, can we consider an option for users to develop a smartapp to directly authenticate with Appleâs HomeKit cloud?
A couple of different things here.
First, smartthings have said for the last year that they are not going to comment anymore on future plans. So I donât think weâll see input on that.
Second, HomeKit doesnât have a cloud. Everything runs locally except for voice recognition through Siri. So all of the device authentication is done locally. Right now the Apple side of the software options discussed in this thread are in early closed beta, but rumors are that it will be released as part of an iOS update later this year. A lot of manufacturers are waiting for that. Weâll just need to see how smartthings responds at that time.
The good news is that if you do want to âroll your ownâ there is an existing software integration called âhomebridgeâ that quite a few community members are using. It does require having a separate laptop or other device like a raspberry pi to act as a âman in the middleâ server and host the software integration. You can get more information about it in the following threads:
Thanks so much for your fast reply - and after a glance back at the software authentication doc via Homekit, youâre right. There isnât a software cloud to sync with. What it might require though, is that Smartthings open up its disabled bluetooth support for a smart app to be able to act as a HomeKit connector, without Homebridge. I have Homebridge running currently on a raspberrypi, but itâs generally unstable and does require a hardware bridge device at home running constantly. It appears that 11.3 will enable Homekit software authentication, so fingers crossed that Smartthings takes this path towards an official (or beta sans-raspberrypi) integration!
So just going to leave my two cents. I am sure I can get one of these alternatives going in a VM but I am shocked that the App that we are supposed to use relies on Samsungâs datcenter with no local control. If I would have realized this I might not even have SmartThings in the house.
Platform is down which is why I am here. I see I can access the API webpages and see my devices but I canât turn anything on/off. We have a recirculating pump on a zwave switch and I currently canât control it.
They need to add HomeKit support just so I can flip the switch locally directly to my hub. I am going to have nightmares now knowing if Smarthings is no more the hub is useless.
Awesome info thanks so much! I just switched from a samsung phone to the new iphone xs. No longer able to create customized voice commands like âok google open garage, etc.â Does your method allow me to use customized voice commands with Siri? For example, âHey siri turn on lights or hey siri lock up?â
I donât use that method myself, so ask in the following thread (this is a clickable link) and the folks there should be able to tell you:
[OBSOLETE] Hello, Home HomeKit (and Siri!) control via homebridge
