Nice resource, thanks. Just want to let you know that the Wemo integration is no longer beta, nor does it require a bridge. The Mini Switches I bought at Costco simply require a firmware update through the Wemo app, and then they work flawlessly with ST and HK—at the same time.
It’s a wiki; you can update it. ![]()
Have you looked into HomeBridge? It will make pretty much any device controlled by ST available to HomeKit. I use it to have Siri voice control ( I run it on Pi, but it runs on several platforms.)
A nice upside is that you can control Z-wave and Zigbee devices directly, so you don’t need to replace existing devices, and also keep your HA traffic off your WiFi network.
Yes, I’ve been considering it, but according to some sources I’ve read, it introduces security vulnerabilities. For now I’ve got similar functionality via the WeMo devices. Since they support both ST and HK, each device acts as a “mini-bridge” between the two systems.
