Hive Window/Door Sensors on ST Hub
Hi all,
I’ve got some Hive window/door sensors (Zigbee HA1.2) that I want to move onto my Smartthings hub.
The hub allows me to add the device but when I go to the API to change the device type there is no such device type as a Zigbee door/window sensor.
Can anyone suggest which device type too use for the sensor to function correctly?
I’ve tried a few but none seem to show the open/closed state correctly.
Darren
Did you try open/closed sensor?
Or smartsense open/closed sensor?
Thanks Mark I’ve tried open/closed sensor.
I just need to go home and check it!
Thanks for your advice. I’ll let you know which works.
Darren
Open/closed sensor works just fine. Thanks Mark
