Hive integration to SmartThings
Samsung announced back in September that Hive thermostats would be available in Smartthings from the middle of October Samsung Expands Energy-Saving Innovations to Help Customers Get Ahead of Peak Energy Season – Samsung Newsroom U.K., but I’ve not been able to find a hive device or service in Smartthings. Anyone else able to add their Hive thermostat yet or know when it’s actually coming?
It does not look like Hive has released it’s integration with SmartThings Energy yet.
You can ask Hive here
I’ll give Hive customer service a try too, but won’t hold my breath. Had about as much luck with their customer service as I have with Samsung.
I got the Smartthings update this morning so expected the support to come with that, but unfortunately not.
Any update on this
Not a peep unfortunately. Hive customer service were no help, and neither was their boards.
Hello,
Frustrating when customer service doesn’t meet expectations. Hopefully, Hive will come through for you this time. Sometimes updates can take a bit to fully integrate, so fingers crossed support will follow soon. Good luck!
Any update on this yet?
I’ve not chased either Smartthings nor Hive since my last fruitless attempt, so far doesn’t look to be any mention of Hive in the Smartthings app. Currently using Alexa and a virtual switch to handle my heating.
I miss being able to set the temperature of each Hive radiator TRV like I could in the old days of SmartThings, and in turn through the Action Tiles dashboard that I have.
I think I may contact support later and see if I can find out more about the progress of this.
Some news and update on the matter everyone. Got this back from SmartThings the other day. Hope this helps.
Hi Elliott,
Thank you for contacting SmartThings.
I asked around a few teams to see what the status of the Hive integration is and there has been a slight delay on the release. The Hive integration is currently in the Certification Phase with the Works with SmartThings team. I don’t have a specific date of when it will be available but it’s looking likely to be released in Q1 of 2025, do stay tuned!
Please feel free to let me know if you have any further SmartThings queries and I will be happy to help.
Have a Merry Christmas and a Happy New Year!
Best regards,
Fiona
SmartThings
Samsung Business Service Centre
Business Hours: Monday to Friday, 9am to 5pm
Thanks for the update Elliot!
From Today Hive is available in SmartThings App
Have added but only heating shows. I’m guessing hot water control has not been implemented.
Thanks for updating here. I’ve add my thermostat successfully :blush:
Looks like only the thermostat shows and the individual Hive Radiator Values are not pulled through and therefore individual room control via routines isn’t possible.
Maybe it’s coming but info on functionality seems non-existent.
Can anyone let me know if this new integration requires a hive hub? Or can you connect a hive thermostat directly to smartthings? Cheers (trying to stick to just one hub :slight_smile: )
The integration is through account linking and not adding devices to a smartthings hub, so you do still need a hive hub.
Cheers, I was hoping as they both use zigbee that I could just add hive devices directly to the smartthings hub
I am guilty for changing the thread title. When is hive coming to SmartThings? was redundant now that Hive is available.
Only the thermostat is available to SmartThings.
Radiator Valves nor EV Charger, I don’t have other Hive Devices (due to limited integration) but am assuming they won’t show in SmartThings.
More work is needed for the integration to be beneficial
