Higher Lumen Smart Bulbs?
I have two lamps that currently use 200-watt incandescent bulbs. I’m looking for a Philips Hue or other Dimmable, RGB bulb that I can use in these lamps and that will output the same lumens. Any suggestions?
Mark
It would help us if you give us a little more information…
Where are these lamps used?
Is colour/rgb a priority?
I don’t know of anything that bright. LIFX are typically the brightest smart bulbs you can get. They do have a SmartThings integration. They are bigger and hotter than most of the other smart bulbs, including hue. They still only go up to 1100 lm which will be about a 75 W equivalent. 200 W would be about 3000 lm.
Are these plug in lamps or in wired fixtures? It may be easier to put a control in the circuit then to find smart bulbs of that brightness.
Yes, I think that is what I will do.
