Currently using sharptools, tasker, and autolocation to run arrival and departure routines. When I depart, tasker will turn on high accuracy mode, but not when I’m returning home and enter the outer geofence?
joshua_lyon
(Josh, SharpTools.io Dashboard)
June 7, 2018, 11:32am
2
Are you using the approach from the following thread?
Update May 9 2017 - I finally have a setup that has been pretty much rock solid for my phone and now my wife’s too. Updating the instructions below to reflect my latest configuration
What is this? An alternative way to set presence in SmartThings using your Android phone. This solution uses three separate mobile phone apps, Tasker, SharpTools, and AutoLocation. These are all paid apps, but you’re looking at a total of around $7.50 for all three. Tasker and AutoLocation are eligible for Google Family, so if you are setting up for multiple family devices you only have to buy them once.
Why would I do this? Presence sensing in SmartThings relies on your phone to update it’s location using standard Android location services. Even if you set your phone to use High Accuracy location settings, …
Yes, I hope I followed it correctly
joshua_lyon Can u tell me why I don’t receive the high accuracy mode from tasker when I start my arrival?
