So once again I’m experiencing delays in a really simple routine.
Contact Sensor “Upstairs basement door” “efb0b54d-2253-47fc-8ea1-9db7e7160632” opens and triggers “Basement Stairway Lights” “e9bf2fde-393e-4f70-9a8f-635466228b13” to turn ON. Most of the time this is nearly instant. Over the last few days I’ve been having delays in this quite simple process of up to several minutes. Below are some CLI logs from a short delay. The time it took to turn on the light from the time the door opened, using a stop watch. (4.7 seconds). Is there anything in this log that jumps out as something to look at?
I also have a motion sensor that will turn these lights on if coming from the other side of the basement. Seems to be a similar delay there as well. (not in this log)
2025-01-01T19:18:45.144984828Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> received Z-Wave command: {args={value=3}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="CRC16", payload="\x03", src_channel=0, version=1}
2025-01-01T19:18:45.347681471Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.360183175Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:18:45.417690116Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.445070544Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":3}}
2025-01-01T19:18:45.452427822Z DEBUG Zigbee Contact driver device thread event handled
2025-01-01T19:18:45.522389490Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.523481735Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.524526129Z WARN Z-Wave Switch Attempted to generate event for e049fe95-649f-42a5-9a20-ed0e1eea6495.main but it does not support capability Contact Sensor
2025-01-01T19:18:45.526614626Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.527742854Z WARN Z-Wave Switch Attempted to generate event for e049fe95-649f-42a5-9a20-ed0e1eea6495.main but it does not support capability Motion Sensor
2025-01-01T19:18:45.536239395Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:45.540655019Z WARN Z-Wave Switch Attempted to generate event for e049fe95-649f-42a5-9a20-ed0e1eea6495.main but it does not support capability Water Sensor
2025-01-01T19:18:45.548796488Z DEBUG Z-Wave Switch Master Bath Lights device thread event handled
2025-01-01T19:18:46.850692756Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:18:46.856383701Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> received Z-Wave command: {args={value=68}, cmd_class="SWITCH_MULTILEVEL", cmd_id="REPORT", dst_channels={}, encap="CRC16", payload="D", src_channel=0, version=1}
2025-01-01T19:18:46.908547856Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:46.909652428Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:18:46.924269116Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:46.925236049Z INFO Z-Wave Switch <ZwaveDevice: e049fe95-649f-42a5-9a20-ed0e1eea6495 [C7] (Master Bath Lights)> emitting event: {"attribute_id":"level","capability_id":"switchLevel","component_id":"main","state":{"value":68}}
2025-01-01T19:18:46.945576832Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:46.946523650Z DEBUG Z-Wave Switch Master Bath Lights device thread event handled
2025-01-01T19:18:48.871266006Z INFO Z-Wave Switch hub handled command: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7:main:switch:off []
2025-01-01T19:18:48.873074018Z INFO Z-Wave Switch hub sending: Z-Wave command (439d7cfa-1159-45f3-a3b9-87b40dbf3ae7): <cmd_class: 0x25, cmd_code: 0x1, dst_channels: [], encap: 0x0, payload: [00], src_channel: 0x0>
2025-01-01T19:18:48.890889648Z TRACE Z-Wave Switch Z-Wave command(f4bfdaf1) queued for radio transmission: CC:Switch Binary, CID:0x01
2025-01-01T19:18:49.214811981Z TRACE Z-Wave Switch Z-Wave command(f4bfdaf1) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:18:49.573086379Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:18:49.619921908Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> received Z-Wave command: {args={value="OFF_DISABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2025-01-01T19:18:50.004815031Z INFO Z-Wave Switch hub sending: Z-Wave command (439d7cfa-1159-45f3-a3b9-87b40dbf3ae7): <cmd_class: 0x25, cmd_code: 0x2, dst_channels: [], encap: 0x0, payload: [], src_channel: 0x0>
2025-01-01T19:18:50.103008702Z TRACE Z-Wave Switch Z-Wave command(be9110d5) queued for radio transmission: CC:Switch Binary, CID:0x02
2025-01-01T19:18:50.133120680Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:50.134291261Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2025-01-01T19:18:50.253207065Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:50.269959601Z DEBUG Z-Wave Switch Basement Lights device thread event handled
2025-01-01T19:18:50.313499654Z TRACE Z-Wave Switch Z-Wave command(be9110d5) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:18:50.375437128Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:18:50.390273164Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> received Z-Wave command: {args={current_value="OFF_DISABLE", duration=0, target_value="OFF_DISABLE", value="OFF_DISABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00\x00\x00", src_channel=0, version=2}
2025-01-01T19:18:50.452899211Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:50.460135966Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2025-01-01T19:18:50.485735284Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:18:50.486685226Z DEBUG Z-Wave Switch Basement Lights device thread event handled
2025-01-01T19:18:53.757011120Z DEBUG Zigbee Switch driver device thread event handled
2025-01-01T19:19:01.666827610Z INFO Z-Wave Switch hub handled command: e9bf2fde-393e-4f70-9a8f-635466228b13:main:switch:off []
2025-01-01T19:19:01.668480200Z INFO Z-Wave Switch hub sending: Z-Wave command (e9bf2fde-393e-4f70-9a8f-635466228b13): <cmd_class: 0x25, cmd_code: 0x1, dst_channels: [], encap: 0x0, payload: [00], src_channel: 0x0>
2025-01-01T19:19:01.693390280Z TRACE Z-Wave Switch Z-Wave command(76c97f4b) queued for radio transmission: CC:Switch Binary, CID:0x01
2025-01-01T19:19:01.875944124Z TRACE Z-Wave Switch Z-Wave command(76c97f4b) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:01.910736344Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:01.913743132Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> received Z-Wave command: {args={value="OFF_DISABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2025-01-01T19:19:01.952647586Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:01.956958763Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2025-01-01T19:19:01.980881754Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:01.981807749Z DEBUG Z-Wave Switch Basement Stairway Lights device thread event handled
2025-01-01T19:19:02.700316399Z INFO Z-Wave Switch hub sending: Z-Wave command (e9bf2fde-393e-4f70-9a8f-635466228b13): <cmd_class: 0x25, cmd_code: 0x2, dst_channels: [], encap: 0x0, payload: [], src_channel: 0x0>
2025-01-01T19:19:02.725704406Z TRACE Z-Wave Switch Z-Wave command(219b87ad) queued for radio transmission: CC:Switch Binary, CID:0x02
2025-01-01T19:19:02.875822227Z TRACE Z-Wave Switch Z-Wave command(219b87ad) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:02.910939076Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:02.914527448Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> received Z-Wave command: {args={current_value="OFF_DISABLE", duration=0, target_value="OFF_DISABLE", value="OFF_DISABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00\x00\x00", src_channel=0, version=2}
2025-01-01T19:19:02.950524773Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:02.958061212Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"off"}}
2025-01-01T19:19:02.976364097Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:02.977325616Z DEBUG Z-Wave Switch Basement Stairway Lights device thread event handled
2025-01-01T19:19:09.807463881Z TRACE Z-Wave Sensor Received event with handler unnamed
2025-01-01T19:19:09.957505323Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event="WINDOW_DOOR_IS_OPEN", event_parameter="", notification_status="ON", notification_type="ACCESS_CONTROL", v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=22, z_wave_alarm_status="ON", z_wave_alarm_type="ACCESS_CONTROL", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00\x00\x00\xFF\x06\x16\x00", src_channel=0, version=3}
2025-01-01T19:19:10.265836539Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.271065298Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.277144215Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"open"}}
2025-01-01T19:19:10.351528630Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.352603842Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.353540332Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.354427055Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.390179919Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.403699948Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.409844207Z DEBUG Z-Wave Sensor Upstairs basement door device thread event handled
2025-01-01T19:19:10.414164671Z TRACE Z-Wave Sensor Received event with handler unnamed
2025-01-01T19:19:10.435883931Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> received Z-Wave command: {args={sensor_type="DOOR_WINDOW", sensor_value="DETECTED_AN_EVENT"}, cmd_class="SENSOR_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF\x0A", src_channel=0, version=2}
2025-01-01T19:19:10.546148812Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.550211447Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.587348286Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"open"}}
2025-01-01T19:19:10.617800927Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.618891506Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.623266734Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.624253782Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:10.625158788Z DEBUG Z-Wave Sensor Upstairs basement door device thread event handled
2025-01-01T19:19:12.299514066Z INFO Z-Wave Switch hub handled command: e9bf2fde-393e-4f70-9a8f-635466228b13:main:switch:on []
2025-01-01T19:19:12.301168572Z INFO Z-Wave Switch hub sending: Z-Wave command (e9bf2fde-393e-4f70-9a8f-635466228b13): <cmd_class: 0x25, cmd_code: 0x1, dst_channels: [], encap: 0x0, payload: [ff], src_channel: 0x0>
2025-01-01T19:19:12.325085691Z TRACE Z-Wave Switch Z-Wave command(e2b420da) queued for radio transmission: CC:Switch Binary, CID:0x01
2025-01-01T19:19:12.555977146Z TRACE Z-Wave Switch Z-Wave command(e2b420da) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:12.600772945Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:12.601725177Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> received Z-Wave command: {args={value="ON_ENABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2025-01-01T19:19:12.633827451Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:12.637820829Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:19:12.662229451Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:12.663197800Z DEBUG Z-Wave Switch Basement Stairway Lights device thread event handled
2025-01-01T19:19:13.329625587Z INFO Z-Wave Switch hub sending: Z-Wave command (e9bf2fde-393e-4f70-9a8f-635466228b13): <cmd_class: 0x25, cmd_code: 0x2, dst_channels: [], encap: 0x0, payload: [], src_channel: 0x0>
2025-01-01T19:19:13.355362004Z TRACE Z-Wave Switch Z-Wave command(6f0389d9) queued for radio transmission: CC:Switch Binary, CID:0x02
2025-01-01T19:19:13.438773444Z INFO Z-Wave Switch hub handled command: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7:main:switch:on []
2025-01-01T19:19:13.440350197Z INFO Z-Wave Switch hub sending: Z-Wave command (439d7cfa-1159-45f3-a3b9-87b40dbf3ae7): <cmd_class: 0x25, cmd_code: 0x1, dst_channels: [], encap: 0x0, payload: [ff], src_channel: 0x0>
2025-01-01T19:19:13.461323621Z TRACE Z-Wave Switch Z-Wave command(ab22b044) queued for radio transmission: CC:Switch Binary, CID:0x01
2025-01-01T19:19:13.566101123Z TRACE Z-Wave Switch Z-Wave command(6f0389d9) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:13.608370186Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:13.619704599Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> received Z-Wave command: {args={current_value="ON_ENABLE", duration=0, target_value="ON_ENABLE", value="ON_ENABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF\xFF\x00", src_channel=0, version=2}
2025-01-01T19:19:13.652211671Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:13.656721332Z INFO Z-Wave Switch <ZwaveDevice: e9bf2fde-393e-4f70-9a8f-635466228b13 [AB] (Basement Stairway Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:19:13.673890785Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:13.674844766Z DEBUG Z-Wave Switch Basement Stairway Lights device thread event handled
2025-01-01T19:19:13.836382540Z TRACE Z-Wave Switch Z-Wave command(ab22b044) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:13.940972135Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:13.949911330Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> received Z-Wave command: {args={value="ON_ENABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2025-01-01T19:19:14.002105095Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:14.006064823Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:19:14.042907642Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:14.043873742Z DEBUG Z-Wave Switch Basement Lights device thread event handled
2025-01-01T19:19:14.469922986Z INFO Z-Wave Switch hub sending: Z-Wave command (439d7cfa-1159-45f3-a3b9-87b40dbf3ae7): <cmd_class: 0x25, cmd_code: 0x2, dst_channels: [], encap: 0x0, payload: [], src_channel: 0x0>
2025-01-01T19:19:14.671092351Z TRACE Z-Wave Switch Z-Wave command(c87b1c46) queued for radio transmission: CC:Switch Binary, CID:0x02
2025-01-01T19:19:15.118800510Z TRACE Z-Wave Switch Z-Wave command(c87b1c46) transmit status: TRANSMIT_COMPLETE_OK
2025-01-01T19:19:15.299122929Z TRACE Z-Wave Switch Received event with handler unnamed
2025-01-01T19:19:15.342330189Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> received Z-Wave command: {args={current_value="ON_ENABLE", duration=0, target_value="ON_ENABLE", value="ON_ENABLE"}, cmd_class="SWITCH_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF\xFF\x00", src_channel=0, version=2}
2025-01-01T19:19:15.450542556Z DEBUG Zigbee Contact driver device thread event handled
2025-01-01T19:19:15.621225089Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:15.623291638Z TRACE Z-Wave Sensor Received event with handler unnamed
2025-01-01T19:19:15.624119849Z INFO Z-Wave Switch <ZwaveDevice: 439d7cfa-1159-45f3-a3b9-87b40dbf3ae7 [7E] (Basement Lights)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2025-01-01T19:19:15.667390828Z TRACE Z-Wave Switch Found ZwaveDispatcher handler in zwave_switch
2025-01-01T19:19:15.679160357Z DEBUG Z-Wave Switch Basement Lights device thread event handled
2025-01-01T19:19:15.795747076Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> received Z-Wave command: {args={alarm_level=0, alarm_type=0, event="WINDOW_DOOR_IS_CLOSED", event_parameter="", notification_status="ON", notification_type="ACCESS_CONTROL", v1_alarm_level=0, v1_alarm_type=0, z_wave_alarm_event=23, z_wave_alarm_status="ON", z_wave_alarm_type="ACCESS_CONTROL", zensor_net_source_node_id=0}, cmd_class="NOTIFICATION", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00\x00\x00\xFF\x06\x17\x00", src_channel=0, version=3}
2025-01-01T19:19:15.865608669Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.870882406Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.911461315Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"closed"}}
2025-01-01T19:19:15.941050513Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.942111982Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.943054302Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.943923409Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.960201016Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.961286057Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:15.963520980Z DEBUG Z-Wave Sensor Upstairs basement door device thread event handled
2025-01-01T19:19:15.964457220Z TRACE Z-Wave Sensor Received event with handler unnamed
2025-01-01T19:19:15.980269019Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> received Z-Wave command: {args={sensor_type="DOOR_WINDOW", sensor_value="IDLE"}, cmd_class="SENSOR_BINARY", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00\x0A", src_channel=0, version=2}
2025-01-01T19:19:15.999078359Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.000238446Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.001900781Z INFO Z-Wave Sensor <ZwaveDevice: efb0b54d-2253-47fc-8ea1-9db7e7160632 [76] (Upstairs basement door)> emitting event: {"attribute_id":"contact","capability_id":"contactSensor","component_id":"main","state":{"value":"closed"}}
2025-01-01T19:19:16.013452877Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.016190799Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.018864003Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.030319273Z TRACE Z-Wave Sensor Found ZwaveDispatcher handler in zwave_sensor
2025-01-01T19:19:16.031248808Z DEBUG Z-Wave Sensor Upstairs basement door device thread event handled```
