I am trying to use multiple motion sensor with single light. Works fine to turn the light on with motion from any sensor. But I want light to turn off, when motion stopped on all motion sensors. So far lights turns off when motion stops on any sensor.
Assuming that you have set up a shortcut in Lights & Switches for the light, then you use “Turn on when there is motion” specifying both motion sensors. Try using “Turn off when there is no motion”, again specifying both motion sensors and the time delay. Use that instead of “Turn off when motion stops” which is in the “Turn on when there is motion” setup. That should work.
