Motion Detected in One Room to Turn Off Lights in Another Room
I’ve seen the lights follow me SmartApp but I was wondering if there’s a way to turn off a light when motion is detected? The idea is when I walk into the bedroom, I want the motion detector in the bedroom to turn the lights off in the living room and also to turn the lights on in the bedroom.
Code sample:
preferences {
      section("When there's movement...") {
          	input "motion1", "capability.motionSensor", title: "Where?", multiple: true
          section("Turn on a light...") {
          	input "switchesOn", "capability.switch", multiple: true
          section("Turn off a light...") {
          	input "switchesOff", "capability.switch", multiple: true
    def installed()
    	subscribe(motion1, "motion.active", motionActiveHandler)
    def updated()
    	unsubscribe()
    def motionActiveHandler(evt) {
    	switchesOn.on()
    	switchesOff.off()
Note: As I have tried this. If you live by yourself, this works. But, if you have family or friends over at night… Well you can see the complication that this causes (SMILE)
@scottinpollock
Thanks Scott!
It works great. I have it setup to only run when I’m in “Home Alone” mode. If my wife and I are both home, or if we have guests over the motion in the master bedroom doesn’t trigger the off switch in the living room.
