Help with github integration
I’m attempting to get setup for GitHub integration. I started to set it up and got to step 2.
Problem is, I did not fully understand what step2 was asking until a bit later. In the meantime I though I would start over and delete the oauth from GitHub. Now I cant get past step 2 or start over back to step 1 to get the oauth back. Just need to see how to start back over. If there is already a topic covering the solution I’ll check there, but I was unable to find the same situation.
Any help is appreciated!
You are the best! thanks for taking the time to help me out. The second suggestion worked like a charm.
Thanks again,
-Jake
sorry to bring up an old thread, but I never get the ‘Enable GitHub Integration’ link
