I am trying to make the following code work but I am having
issues.
/// @file
/// @brief
/// Arduino SmartThings Shield LED Example with Network Status
/// @note
/// ______________
/// | SW[] |
/// |[]RST |
/// | AREF |–
/// | GND |–
/// | 13 |–X LED
/// | 12 |–
/// | 11 |–
/// --| 3.3V 10 |–
/// --| 5V 9 |–
/// --| GND 8 |–
/// --| GND |
/// --| Vin 7 |–
/// | 6 |–
/// --| A0 5 |–
/// --| A1 ( ) 4 |–
/// --| A2 3 |–X THING_RX
/// --| A3 ____ 2 |–X THING_TX
/// --| A4 | | 1 |–
/// --| A5 | | 0 |–
/// |____|
#include <SoftwareSerial.h> //TODO need to set due to some weird wire language linker, should we absorb this whole library into smartthings
#include <SmartThings.h>
// Pin Definitions | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
// V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
#define PIN_LED 13
#define PIN_THING_RX 3
#define PIN_THING_TX 2
// Global Variables | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
SmartThingsCallout_t messageCallout; // call out function forward decalaration
SmartThings smartthing(PIN_THING_RX, PIN_THING_TX, messageCallout); // constructor
bool isDebugEnabled; // enable or disable debug in this example
int stateLED; // state to track last set value of LED
int stateNetwork; // state of the network
int relay1 = 7; // energize relay1 shield pin 7
int relay2 = 6; // energize relay2 shield pin 6
// Local Functions | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
// V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V
void on()
stateLED = 1; // save state as 1 (on)
digitalWrite(PIN_LED, HIGH); // turn LED on
digitalWrite(relay1, HIGH); // energize relay1
delay (1000); // hold relay1 on for 1 second
digitalWrite(relay1, LOW); // deenergize relay1
smartthing.shieldSetLED(0, 0, 2);
smartthing.send(“on”); // send message to cloud
void off()
stateLED = 0; // set state to 0 (off)
digitalWrite(PIN_LED, LOW); // turn LED off
digitalWrite(relay2, HIGH); // energize relay2
digitalWrite(relay2, LOW); // deenergize relay2
smartthing.shieldSetLED(0, 0, 0);
smartthing.send(“off”); // send message to cloud
void setNetworkStateLED()
SmartThingsNetworkState_t tempState = smartthing.shieldGetLastNetworkState();
if (tempState != stateNetwork)
switch (tempState)
case STATE_NO_NETWORK:
if (isDebugEnabled) Serial.println(“NO_NETWORK”);
smartthing.shieldSetLED(2, 0, 0); // red
break;
case STATE_JOINING:
if (isDebugEnabled) Serial.println(“JOINING”);
break;
case STATE_JOINED:
if (isDebugEnabled) Serial.println(“JOINED”);
smartthing.shieldSetLED(0, 0, 0); // off
break;
case STATE_JOINED_NOPARENT:
if (isDebugEnabled) Serial.println(“JOINED_NOPARENT”);
smartthing.shieldSetLED(2, 0, 2); // purple
break;
case STATE_LEAVING:
if (isDebugEnabled) Serial.println(“LEAVING”);
break;
default:
case STATE_UNKNOWN:
if (isDebugEnabled) Serial.println(“UNKNOWN”);
smartthing.shieldSetLED(0, 2, 0); // green
break;
stateNetwork = tempState;
// API Functions | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
void setup()
// setup default state of global variables
isDebugEnabled = true;
stateLED = 0; // matches state of hardware pin set below
stateNetwork = STATE_JOINED; // set to joined to keep state off if off
// setup hardware pins
pinMode(PIN_LED, OUTPUT); // define PIN_LED as an output
digitalWrite(PIN_LED, LOW); // set value to LOW (off) to match stateLED=0
if (isDebugEnabled)
{ // setup debug serial port
Serial.begin(9600); // setup serial with a baud rate of 9600
Serial.println(“setup…”); // print out ‘setup…’ on start
void loop()
// run smartthing logic
smartthing.run();
setNetworkStateLED();
void messageCallout(String message)
// if debug is enabled print out the received message
if (isDebugEnabled)
Serial.print(“Received message: '”);
Serial.print(message);
Serial.println("’ ");
// if message contents equals to ‘on’ then call on() function
// else if message contents equals to ‘off’ then call off() function
if (message.equals(“on”))
on();
else if (message.equals(“off”))
off();
