Can someone help explain to me what the simulator raw data is, and how to decipher it, on the example thing shield code? Also what is the catchall for?
metadata {
// Automatically generated. Make future change here.
definition (name: "On/Off Shield", namespace: "smartthings", author: "SmartThings") {
capability "Actuator"
capability "Switch"
capability "Sensor"
// Simulator metadata
simulator {
status "on": "catchall: 0104 0000 01 01 0040 00 0A21 00 00 0000 0A 00 0A6F6E"
status "off": "catchall: 0104 0000 01 01 0040 00 0A21 00 00 0000 0A 00 0A6F6666"
// reply messages
reply "raw 0x0 { 00 00 0a 0a 6f 6e }": "catchall: 0104 0000 01 01 0040 00 0A21 00 00 0000 0A 00 0A6F6E"
reply "raw 0x0 { 00 00 0a 0a 6f 66 66 }": "catchall: 0104 0000 01 01 0040 00 0A21 00 00 0000 0A 00 0A6F6666"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 2, height: 2, canChangeIcon: true, canChangeBackground: true) {
state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
main "switch"
details "switch"
// Parse incoming device messages to generate events
def value = zigbee.parse(description)?.text
def name = value in ["on","off"] ? "switch" : null
def result = createEvent(name: name, value: value)
log.debug "Parse returned ${result?.descriptionText}"
return result
// Commands sent to the device
def on() {
zigbee.smartShield(text: "on").format()
