First, you need to use a device type handler that will expose the parameter to SmartThings. I’m not sure which one you have been using, but the one in the following thread will work.
Once you have that, you can create a piston in WebCore that can reconfigure the motion sensor parameter based on time of day or a number of other variables. Again, the people in the following thread can help tell you how to do that, as several of them have it set up that way.
