Hello Tyler.
So, I might not understand, but when you say that these devices are not waterproof, does that mean that they are pretty much single use or they have to really get flooded to not work any more?
Thanks, Chris
Hello Tyler.
Thanks, Chris
Theyāre not single use. They actually float and I donāt see air bubbles coming out of it when itās floating around - but itās not certified water proof. Iām trying to get my hands on the testing data to see if we have any official wording but in the mean time I donāt think that thereās any issues with it being āsubmergedā in water.
From the looks of it has two metal sensors at the bottom of the device and a slot on the side to pull for battery / initial pairing.
That slot looks like water could get in.
As Tyler said, it looks like it would float, but if water got in the side slot, my guess is it would be fried.
I wouldnāt strap it down to the side of a pipe in my sump pump, like my other water sensor. Or atleast Iād tape up the side before thatā¦
I think it includes a standoff clip-on / remote leads? But can someone from Smartthings confirm this? That would be ideal for keeping the electronics dry but drop the leads into a water prone area.
The Moisture sensor pull tab is on the interior of the device. Thereās no hole on the outside (as with the other devices) to prevent water from getting in.
The two metal contacts on the bottom are in there tight and water canāt get in from there.
I paired one of the new moisture sensors and completely submerged it in water for 1 minute. It immediately reported a āwetā status upon submersion and immediately reported a ādryā status when removed. Opening the enclosure showed some water had collected on the inside but the device was still completely operational.
As an aside, the FortrezZ sensor manual tells you to caulk the holes and I think even the sides for true waterproofing. I donāt see why that couldnāt be done here also but I donāt think that was tested.
Remote leads are not included.
Iāve personally installed over 100 FortrezZ moisture sensors in real world scenarios and Iām very impressed with this new moisture sensor in particular.
edit: If there are any other tests or stress tests anyone wants to see with the new devices let me know!
Bummer, the Centralite āOEMā spec shows a remote lead capability, too bad this doesnāt come with it.
I assume if someone could get the remote leads from another provider, then it could work, or just solder on them?
Iād assume so also. Let me follow up on that.
Iāve had the FortrezZ version submerged about half a dozen times so far as a low salt warning in my water softener. Each time it quickly filled with water even with caulking. I think it comes through gaps at the contacts. Each time the FortrezZ model has survived to my surprise.
Iām looking for something more convenient since it takes me about 1/2 hour to open up, dry out and re caulk.
The other three places I use the sensors havenāt luckily been tested in real life.
My need with the water softener is rather unique. Yet even though you would think the salt brine would quickly damage it, it still survives. Is your new unit easier to open?
Did you determine if rechargeable CR-2s work?
Yes, the device is easier to open. You just pull the top of the enclosure off.
I donāt have a rechargeable CR2 to test with but I looked at the specs on some of the batteries and they look like theyāll work fine.
I have two of these and I like them a lot. If the contacts are mounted correctly, it also instantly shows when the water goes back down.
http://www.lowes.com/pd_422362-45367-TST01-1_0__?productId=4740940
And they are inexpensive at only $30.
So these work with ST? Are they zwave or zigbee?
Zwave. Work great. I have two of them. Recognized right away without issue.
Bummer, really want to stick to zigbee. Might have to try out the ST moisture sensors then.
I would say there are situations where the ST sensor would be better, like under a sink. Just easier to setup since you just set it in there. The one I posted would be great in sumps, etc. I guess it depends in the situation.
As for zwave vs zigbee. Doesnāt matter much to me. I have zwave dimmers and a combination of zigbee and zwave door sensors. I also have a mix of motion sensors. Iām really trying to narrow down the devices I like the best. Personally I donāt see a reason to stick with one or the other protocol.
What was your reason for wanting to stick to one? Iām curious.
I also have one if these for my sump pump. Luckily, the sump pump hasnāt failed so I have not had a real life test yet. The battery status doesnāt seem to update correctly, though. But I find battery status is iffy on most devices.
Lots of reasonsā¦ Some logical, some irrationalā¦
I have over 70 zigbee devices (mostly control4, card access (now owned by control4) and a few other manufacturers)
I have only about a half a dozen z-wave devices so far.
My reasons / observations:
Battery life seems to be far better on zigbee
Reliability seems better, but this is really subjective
Openness of Zigbee vs lockdown of Z-wave (double edge sword, see control4ās usage of zigbee)
Cost, this clearly goes to Z-wave but hopefully zigbee device adoption will drive prices down
Ultimately, as I gain more knowledge about zigbee, I donāt want to learn z-waveā¦
Plus, for ultimate portability, for example, if ST went away tomorrow, or I wanted to take my ST zigbee things to another platform, I know I can make the zigbee stuff work with my Control4 system. Z-wave, not so much without another hub involved.
Time will tell when Apple, Google and Microsoft throw their R&D dollars behind a standard, or another will emerge.
For now, Iām sticking with Zigbee just out of using it the mostā¦ Nothing really against Z-wave, as the great thing now with ST is you can use bothā¦
Rechargeable batteries have different discharge curves. If the device is not designed to recognize rechargeables, then they may indicate a battery is dead when in fact there is plenty of charge left. The FortrezZ moisture sensors have this issue.
Well you just taught me something! Iāll get a battery ordered and test for you.
Is the temperature sensor on the multis any more accurate than the old ones? Mine are always off 5+ degrees.
Much more accurate, plus weāve added manual temp offsets.
I have a question on the SmartSense motion Detector, Can I mount this outside under my soffit which will be protected from rain and snow. Has this unit been tested in sub-zero temperatures?
