Has anyone had any success with Qubino flush dimmers?
I am having a very bad flickering problem with Qubino dimmer any time it is less than 95%.
I have 5 of them and one buzzes at anything less than 100 and doesn’t smoothly dim when turned off. It looks like my electrician crammed them into a box that was too small and this one has some physical damage- any damage on yours?
Completely new ST user here can someone help me out here please?
I have the qubino flush dimmer relay and need to adjust parameter no.1 from 0 to 1.
I have no idea where to start with this. Where is this parameter? I cannot connect to the relay over the network as its not IP enabled…
It seems like its probably an XML file somewhere or something like that but nowhere is there clear documentation on how to do this.
In regards to the Qubino Flush Dimmer you can use my device handler that supports configuration parameter and association settings. Currently it doesn’t support I2 and I3 configurable inputs due to the ST platform not recognizing the device with both enabled for some reason.
You can find my handler here (the device would need a reinclusion after installing this handler, due to the association setting in inclusion. After you change the configuraion parameter values on the preference screen be sure to press “Set configuration” in the detailed view of the device, so that the values will get sent to the physical device):
Additionally, there’s another good handler available from @erocm1231 , you can find it here:
Its working flawlessly for me… Really happy with it.
After a few tweaks of the parameters its doing exactly as it should…
