There are a couple of ways to skin this cat. As mentioned above, RuleMachine, or even the standard ST SmartSwtich app can be used. But, if you want to control this behavior from your Harmony Remote, then you will probably have to create two different Harmony events? (e.g. the first one to call the ST switch/routine – which turns on the power strip, then waits a bit, then triggers the second Harmony event to indeed turn on all of the TV-related stuff.)
Or…
You MIGHT be able to do all of this within a single Harmony event. Basically, just realize that your first/initial commands won’t be “heard” by your entertainment devices, because they are powered-off. So, the first event that will be “heard/obeyed,” is the power-strip “on” command. Then, you simply add ADDITIONAL commands for the TVs and such. e.g. SECOND power and HDMI/input selector events for all of your devices (that DO get heard.)
I do something VERY similar for my Harmony events, so they will work whether the TV/equipment is “on” or “off.” e.g. the FIRST pass is so things happen FAST (when the gear is already on.) Change channels, or switch HDMI inputs, etc. I then insert pauses… and then repeat the commands. This way, they work when all of the gear is OFF, too. Because: When they are OFF, they need the extra time/pauses while the systems boot-up. By then, the “second set” of commands are being executed. Granted, when the TV/gear is already “on” – I see TWO events. e.g. The FIRST event to IMMEDIATELY switch to HDMI2 (which it quickly obeys.) Then, after it’s now already made the switch to HDMI2, I see another/second “HDMI2” message on my TV. But, nothing really happens, because it’s now already on HDMI2.
Just BE CAREFUL not to run two of these commands too soon/adjacent to one another, else you will find yourself in a loop! e.g. You are initially tuned to HDMI1. You hit the command to switch to HDMI2. Midway between switching to HDMI2, you then (also) issue an HDMI1 command. Which it will immediately obey, and flip back to HDMI1. Then, your initial script sends its second request to tune to HDMI2 – which it does. Then, your first script triggers its second command, to switch back to HDMI1. (Rinse & repeat…)
So, if/when you issue a device-change or whatever, you need to wait for the FULL script to run, before initiating another command/script. (This also happens when you don’t have decent “exit” commands properly defined in your Harmony events. e.g. everything you turn “on” as you enter the event, needs to be respectively turned “off” as you exit that script.)
Good luck!
