It’s a combination bug with the Schlage lock, mesh delays and the stock device handler. You can try to use this device handler which puts in a fix for the issue caused by the lock sending a delayed event (it sends two events for each unlock event and if the mesh delays it further then the stock device handler doesn’t handle it correctly). You can also do a z-wave repair which may temporarily help.
RBoy
2
Related topics
| Topic | Replies | Views | Activity | |
| New Schlage Connect wrong type/issues with Guest Access | 3 | 1532 | October 19, 2020 | |
| Smart Lock Guest Access "No Locks Are Online. Try Again Later" | 40 | 6965 | June 2, 2022 | |
| Push Notifications for Schlage Lock Not Working (April 2019) | 106 | 22392 | June 19, 2020 | |
| Schlage Connect Z-Wave incomplete notifications | 5 | 676 | June 28, 2022 | |
| Schlage Z-wave Lock Command Works Occasionally | 52 | 11502 | July 23, 2016 |
