Grouping switches together
Hi,
I’m new to SmartThings, looking to change from an Insteon setup with ~10 light switches over to a more modern and less fragile technology. A core setup that I have been doing with Insteon is 3 separate physical dimmers in a living room that each switch a circuit of recessed lights. In insteon I grouped these switches together that each one of them would switch all 3 circuits together on and off. I also had the option with a remote to individually switch the circuits on and off.
Is this possible with SmartThings/ZWave? What is the lag in such a setup, do all circuits switch simultaneous?
Thanks,
Alex
You can do it with the official smartlighting feature by just having one switch follow another. There’s a how to article in the community – created wiki that explains:
http://thingsthataresmart.wiki/index.php?title=How_to_Group_Lights_Together
As far as lag or a “popcorn effect”, you just have to try it and see. It won’t be simultaneous, but whether there’s a perceptible lag just varies from set up to set up.
Are you looking for a physical switch, or a virtual/software switch?
If it is physical, you could use something like an Aeon Labs Minimote to toggle switches on/off.
If you want to control with a software switch then there are several options to control them simultaneously.
  1. You could use the Smart Lighting app that @JDRoberts suggested to turn switches on when another switch is turned on. You may need 1 copy of this app for each controlling switch.
  2. Create Scenes that control the on/off state and dimming levels of your switches for different routines to use. Scenes can also be used by apps like the Smart Lighting app. This makes sense in instances where you want to create the same combination (e.g. all 3 circuits on/off) with several different actions (e.g 3 different physical switches).
As @etbrown mentioned, you also have the option to use a handheld remote along with the dimmer grouping.
The following topic lists buttons and remotes that have been verified to work with SmartThings. This includes both battery operated and mains powered devices, so read the descriptions carefully.
