I am brand new to the Rules API and until yesterday had never heard of Postman or JSON. I was able to successfully use the GET command to retrieve my Location and location ID as well as my total Device list. I have set up an environment in Postman and created variables for my Location and the Dimmer Switch ID that I am using for testing. I have also been able to successfully use the POST command to turn my switch on and off.
As I am ultimately hoping to be able to create a complex routine with this switch, my next step was to create a rule with a corresponding “actions” set. The first thing I tried was to GET a list of the rules from my hub. I’ve also tried creating a naked rule as well as one that just turns on the switch. I keep getting either 403 or 406 errors. I have tried searching for help and did find a couple of forum threads that came close to what I’m dealing with, but have been unable to resolve my problem.
I’ve been using the Postman Smartthings public workspace as a guide for writing my own Postman inquiries. The public workspace has a section for retrieving rules: Retrieve All Rules. I also tried it with adding “/rules” to the GET URL request.
Thank you for your reply. If I add an Accept Header with the value of “application/vnd.apl+json”, I get the 406 Not Acceptable error. If I delete the Accept Header, I get the 403 Forbidden error, with no body contents.
I created the access token earlier today. There must be some other setting requirement that I am not aware of that is preventing my messages from working.
I thought I could use any variable name, but I see that it does need to say locationid. I made that change and tried with both my Rules Token environment variable and with the actual token value… same results. If I do not include an Accept header, I get the 403 forbidden error, with no explanation.
I did use the Samsung Token generator. https://api.smartthings.com/v1/devices/{{BayWindowSw}}?locationid={{MyLocation}} works just fine and provides a complete device listing for my Bay Window Switch. Anything asking for rules gives me the errors.
When you are specifying a query string in an API call, make sure you get the case correct. SmartThings are very keen on camelCase so the key to filter on a location is locationId with the uppercase I and lower case d.
Rules are quite unusual in that they require that you filter on the unique ID for your SmartThings Location in the query string. You can see all your Locations, and the locationId for each, by making an API call to /locations.
The Accept header isn’t usually necessary but if you use it then it should either be:
Accept: application/json
or
Accept: application/vnd.smartthings+json;v=1
If you use the second format do not include the /v1 at the start of the URL path. They are alternative ways of specifying the API version number. You don’t actually need either unless you venture into undocumented places (I do).
