GE Z-Wave Plus In-Wall Smart Switch Toggle - Use With Fan?
Hello,
I have a few GE Z-Wave Plus In-Wall Smart Switch, White Toggle (14292) switches laying around and was wondering if it’s possible to use these to replace a switch connected to a ceiling fan.
I know that I will not be able to control fan speed, and I am fine with that as I can control the speed from the pull chain on the fan. I basically just want this to operate like a dumb on-off switch for the fan.
Is this possible or will it cause problems? I’ve read conflicting information on if it’s possible or not and would like to get a solid answer before I swap out the switches.
Thanks in advance!
no problem.
As long as it’s within this spec then you are OK.
Power 120VAC, 60Hz
Signal (Frequency) 908.4/916 MHz
Maximum load: 960W Incandescent, 1/2 HP Motor or 1800W (15A) Resistive
Range: Up to 150 feet line of sight between the wireless controller and the closest Z-Wave device
Operating Temperature: 32-104° F (0-40° C)
Requires neutral wire
