GE Z-Wave Dimmer
So I bought 2 of the dimmer switches. Not realizing it at the time. I can use them as just a regular on/off switch right? Where I was going to put these switches, a dimmer can not be used. But since I’m not using the dimmer functionality. Shouldn’t be an issue right?
I know this has been asked. I’ve searched. But sometimes searching and I don’t stuff on here turns into a second job. Lol Thanks in advance!
It depends on the reason.
  • If the amperage exceeds the switch specs, then you must not install it.
  • If there is a danger of damaging the stuff you are powering, same. Too much of a chance you’ll dim by accident.
  • If there’s any other electrical risk (eg, a dimmed motor can overheat, possibly).
I used a dimmer switch with non-dimmable CFL bulbs for a while. Other family members had trouble as they would hold the button and dim rather than tapping it off and on. I created a webcore piston or maybe it was SmartLighting SmartApp to force the dimmer to 100% or 0%. It didn’t work great but helped.
I was thinking of a piston as “back up”. If dimmer is dimmed to 95% then set level to 99%. Or something along those lines.
The default switch settings cause the lights to ramp up and down so you’ll want to adjust them to eliminate that.
Can you elaborate on that?
Are you referring to a light fixture with non-dimmable bulbs?
Or a switch for an appliance/motor load?
I think there would be a big difference in potential safety issues, even if using software to restrict the dimmer to function at either 0% or 100% brightness (i.e. on/off). As @MarkTr mentioned the dimmer will ramp up and down to turn on/off.
Oh ya, I used a custom DH as well. This is probably what you need:
Also, if the switch is turned on, set dimmer to 100%
I have are several fixtures in hallways and such that have intirgrated LEDs. It states on the fixture they are “non dimmable”.
Just buy some GE Z-Wave Plus Switches and return the dimmers. They are on sale at Amazon for ~$30 today.
Provided your items are fairly new (Z-Wave Plus), we made switch mode available on our dimmers. If your fixtures are within spec of the dimmer’s ratings, feel free to use it as a switch! To enable switch mode, tap the top button 5 times then tap the bottom button 5 times. The LED will signify it was successful by blinking 3 times at you. You can switch back to dim mode by doing the same.
For the rest of the week!
