Gasparian:
Hi David,
I’ve already added the remote (45601) to the hub (steps 1-5) with success. Following that, only errors. Made a small video to show what happened:Setup GE 45601 on smarthings hub, not working.Am I doing something wrong? Thank You!
It won’t work with SmartThings. The 45601 is a discontinued model and requires a zwave command class that ST does not support, while ST uses a zwave command class the 45601 does not support.
much discussion of this in the forums, just search on 45601. Here’s one of the most recent:
Was hoping the smartthings smart people could help me out again!
I’ve seen several secondary remote options listed on the forums, GE 45600, the Aeon Minimote, I have a pretty basic setup right now, and was curious if you guys might know which one would work better for the following:
In our bedroom we have a ceiling fan, which I’ve hooked up to one of the new GE speed control GE 12730, and will be installing a Linear WD500Z for the light control, and probably install a 3-way dimmer in the hall.
Ideally I’d like to be able to control the fan speed, lights in bedroom on/off and dim, and then the hall lights on/off/dim. Any recommendations on which of these would work?
Thanks as usual guys
