First Project - Please advise. What Switch do I need?
I finally decided on Smartthing hub. My first project is to replace two switches that control the lights outside my house. Here is the link
Any thoughts? Please advise. All I want to do is schedule lights on and off. Maybe get a little fancy later by adding a sensor to determine sun light and shut off/on
Thanks in advance.
Hi this is a addon switch that is use for a 3-way Setup.
DO NOT BUY THIS ONE
My guess you are automating on/off lights (not dimmers), if thats the case then
This one would be the one you should be buying
or
I’m hoping this is the switch you purchased for the 2nd switch in a 3-way switch setup. This is an add-on switch. It contains no radio to connect to the SmartThings hub. It relies on a primary z-wave switch to talk to the hub.
That’s just an add-on (slave) switch for the switches listed in the post. These are used to expand a GE Toggle Switch-12727 for 3 way or 4 way operations.
Check out the newer Z-Wave Plus switches. The GE compatible would be 14292.
You can easily schedule lights to turn on and off with any light which is controlled by SmartThings. So it’s just a question of selecting the right light.
You said you have two switches – – do they both control the same light? Or are they controlling different lights?
If they are both controlling the same light, then in the US that is called a “three-way” set up. A common example would be the lights over the basement stairs. You might have one switch at the top of the stairs and another switch at the bottom of the stairs which both control the same light. :sunglasses:
:level_slider::bulb::level_slider:
Three ways work a little differently with networked switches then they do with non-networked switches. One switch, the one that actually controls the current load to the light, Will be the master. The other switch will be the auxiliary, which GE calls an “add on.”
When you flip the add on switch it sends a message to the master and the Master actually controls the current to the light. The following FAQ explains more about that.
As others have mentioned, the specific device you linked to is an add on switch, which is why the product description says “not a standalone switch.” But that’s fine as long as both of your switches control the same light and the other switch is a master switch.
If by chance you bought two add-ons by mistake, you just need to return one of them and instead get a matching master switch for the master position.
However, if your two light switches control two different lights then you need to have two master switches, one for each light.
There is an excellent FAQ on wiring GE switches which should help a lot once you get the correct devices:
Thank you for the explanation! I am new and my question while readying everyone’s post was “What is a three way switch” your explanation helped. The switches control separate lights. I will make sure to buy two masters.
Ok, thank you! I need two master switches since they control different lights. I’m sure my novice is showing here but this community seems to be willing to help.
Thanks again.
