If you are having difficulties connecting ZCOMBO here is the solution.
ZCOMBO must be reset to factory setting. This you can do by keep pressing the button until you hear a long beep, after you slide in the batteries. It takes about 15 seconds. Then you can release the button. After that you pull the battery slide out. Now you can go into pairing mode on the hub, and do the usual procedure.
Every thing will work fine ! CHEERS !
