I wanted to include a Fibaro roller shutter / blind controller FGRM-222 and unfortunately it does not work. Do you know how to use that device? How do I install it?
If it does not work, which device is best for controlling the roller shutter with ST?
Hi CristianGM, you´ve added as a Fibaro Dimmer?
Like: “Create New Device Handler” and then selected “From Template”, then selected on the Templates “Fibaro Dimmer”.
So now you have an ON/OFF switch and then a percentage. So how do you control to have the Fibaro module closing 2 dif outputs (one for the motor to go up, the other to go down)?
