Fibaro RGBW 441 as 4 independent channels on ST Edge
Hi:
If you would like to control the Fibaro RGBW 441 as 4 dimmers, you can use this driver. It will create 4 childs that you can move to any room (individually), with ON/OFF command as well as LEVEL for each channel. It will create a fifht child (number 1), that it’s just a mirror of the general status, that can be used as ALL ON/ALL OFF or to sync dimm levels amongst the 5 childs.
I don’t have a 442 version, therefore I can’t confirm if it works, although it should. If anyone tries it on their hub, please let us know the outcome!
Amazing, thanks so much for sharing this. It works like a charm!
Thanks for your message!
