Hello Friends,
Will there be a driver for Fibaro Walli Switch / would be a real shame if nothing would come for it
Hello Friends,
Do you have one? Have you tried it?
There’s a driver for the Walli double switch and Walli dimmer.
deviceLabel: Fibaro Walli Double Switch
manufacturerId: 0x010F
productType: 0x1B01
productId: 0x1000
deviceProfileName: fibaro-walli-double-switch
deviceLabel: Fibaro Walli Dimmer Switch
productType: 0x1C01
productId: 0x1000
deviceProfileName: fibaro-walli-dimmer
Thank you for your reply,
This is all new territory for me with Aeotec / Smartthings,
I know how to install drivers but not how I can / should test what you mentioned
If you already have one of those switches, try to connect it to your hub. It should work out of the box.
I have connected it but it only goes on and off.
But I can’t change the colour of the ring
Login here:
https://my.smartthings.com/advanced/devices
Select the device, make some screenshots (full height and width) and post them here.
In the SmartThings app, click on the device, three dots in the upper right corner, screenshots from driver, information and settings.
The driver offers quite a lot of settings…
The fingerprint of your device is so close and yet so far from the stock driver.
010F/1A01/1000
That means I have to wait a little longer to see if it works properly
Hi @Tabsi,
See page 15 of the manual to see configure as single or double switch.
This device can works as single o double switch.
Exist in zwave alliance as single switch with 0x1A01 or double switch with 0x1B01.
You need select single or double switch prior to add device to zwave network.
I think, when you change to double switch then the fingerprint will change to 0x1B01 and can work with stock driver, but i do not sure
i think you need factory reset, this set a default value to double switch
Try pair without change to single switch mode
The goal is to pair it in double switch mode. Earlier in this thread I’ve mentioned that there’s a driver for the double switch and a dimmer.
Thank you
Factory Reset I have done 2 times.
1x for single switch Mod
and another time for double switch Mod but I didn’t have the driver yet try again if I find the driver
there is a link to the drivers ?
It’s included, it’s a stock driver.
When is in double switch mode, wath you see in the smartthings page?. 1A01 or 1B01?
I See 1A01
Hello friends, after I have replaced the switch in the shop and installed the new one and as a double mod switch I can now set everything. Does anyone know if this option will also be available for Sigel Mod as I don’t need a double switch in every room?
can the 4 LEDs be set separately top / bottom
because I connect the switch as a changeover switch otherwise 2 LEDs always light up permanently
Had a quick look at it.
The driver was added in a huge bundle with dozens of other drivers of all kinds in November 2021. No idea why only the double switch (mode) is supported. It’s quite elaborate, so maybe it originally came from Fibaro?
I would reach out to the Fibaro support - maybe they know more about it.
Nope. All or nothing for both, the on and off behavior from what I can see from a first glance.
