Hi last 5 days i tried use single switch fibaro fgs 212 to switch on and off my a/c but when i switch on or off i use dry connector signal need be send on and after second off to state on and same thing to switch my a/c off. I tried all device handler from that forum and all don’t work like i expect. Closer one its this
- Fibaro Single Relay (FGS-212)
- v.0.0.1
metadata {
definition (name: “Fibaro Single Relay FGS-212 2”, namespace: “JoneLura”, author: “Jone Lura”, mnmn: “SmartThings”, vid:“generic-relay”) {
capability “Switch”
capability “Button”
capability “Configuration”
capability “Health Check”
capability “Refresh”
command "reset"
fingerprint deviceId: "0x1001", inClusters:"0x20, 0x25, 0x27, 0x60, 0x70, 0x72, 0x73, 0x7A, 0x85, 0x86, 0x8E"
tiles (scale: 2) {
multiAttributeTile(name:“switch”, type: “lighting”, width: 3, height: 4){
tileAttribute (“device.switch”, key: “PRIMARY_CONTROL”) {
attributeState “off”, label: ‘{name}', action: "switch.on", icon: "st.switches.switch.on", backgroundColor: "#ffffff", nextState:"turningOn"
attributeState "on", label: '{name}’, action: “switch.off”, icon: “st.switches.switch.off”, backgroundColor: “#00a0dc”, nextState:“turningOff”
tileAttribute(“device.multiStatus”, key:“SECONDARY_CONTROL”) {
attributeState(“multiStatus”, label:’${currentValue}’)
main(["switch"])
details(["switch"])
preferences {
input (
title: "Fibaro Single Relay FGS-212 manual",
description: "Tap to view the manual.",
image: "http://manuals.fibaro.com/wp-content/uploads/2016/08/switch2_icon.jpg",
url: "https://manuals.fibaro.com/content/manuals/en/FGS-212/FGS-212-EN-A-v1.1.pdf",
type: "href",
element: "href"
parameterMap().each {
input (
title: "${it.num}. ${it.title}",
description: it.descr,
type: "paragraph",
element: "paragraph"
input (
title: null,
description: "Default: $it.def" ,
type: it.type,
options: it.options,
range: (it.min != null && it.max != null) ? "${it.min}..${it.max}" : null,
defaultValue: it.def,
required: false
input ( name: "logging", title: "Logging", type: "boolean", required: false )
//UI and tile functions
private getPrefsFor(String name) {
parameterMap().findAll( {it.key.contains(name)} ).each {
input (
title: “{it.num}. {it.title}”,
type: it.type,
range: (it.min != null && it.max != null) ? “{it.min}..{it.max}” : null,
required: false
def on() {
encap(zwave.basicV1.basicSet(value: 255))
def off() {
encap(zwave.basicV1.basicSet(value: 0))
def refresh() {
def cmds =
cmds << zwave.switchBinaryV1.switchBinaryGet()
encapSequence(cmds,1000)
def ping() {
log.debug “ping()”
refresh()
def installed(){
log.debug “installed()”
sendEvent(name: “checkInterval”, value: 1920, displayed: false, data: [protocol: “zwave”, hubHardwareId: device.hub.hardwareID])
response(refresh())
//Configuration and synchronization
def updated() {
if ( state.lastUpdated && (now() - state.lastUpdated) < 500 ) return
logging(“Executing updated()”,“info”)
state.lastUpdated = now()
syncStart()
private syncStart() {
boolean syncNeeded = false
Integer settingValue = null
if(settings."$it.key" != null) {
settingValue = settings."$it.key" as Integer
if (state."$it.key" == null) { state."$it.key" = [value: null, state: “synced”] }
if (state."$it.key".value != settingValue || state."$it.key".state != “synced” ) {
state."$it.key".value = settingValue
state."$it.key".state = “notSynced”
syncNeeded = true
if ( syncNeeded ) {
logging(“sync needed.”, “info”)
syncNext()
private syncNext() {
logging(“Executing syncNext()”,“info”)
def cmds =
for ( param in parameterMap() ) {
if ( state."$param.key"?.value != null && state."param.key"?.state in ["notSynced","inProgress"] ) {
multiStatusEvent("Sync in progress. (param: {param.num})", true)
state."$param.key"?.state = “inProgress”
cmds << response(encap(zwave.configurationV2.configurationSet(configurationValue: intToParam(state."$param.key".value, param.size), parameterNumber: param.num, size: param.size)))
cmds << response(encap(zwave.configurationV2.configurationGet(parameterNumber: param.num)))
break
if (cmds) {
runIn(10, “syncCheck”)
sendHubCommand(cmds,1000)
} else {
runIn(1, “syncCheck”)
def syncCheck() {
logging(“Executing syncCheck()”,“info”)
def failed =
def incorrect =
def notSynced =
if (state."$it.key"?.state == “incorrect” ) {
incorrect << it
} else if ( state."$it.key"?.state == “failed” ) {
failed << it
} else if ( state."$it.key"?.state in [“inProgress”,“notSynced”] ) {
notSynced << it
if (failed) {
multiStatusEvent("Sync failed! Verify parameter: ${failed[0].num}", true, true)
} else if (incorrect) {
multiStatusEvent("Sync mismatch! Verify parameter: ${incorrect[0].num}", true, true)
} else if (notSynced) {
multiStatusEvent("Sync incomplete! Open settings and tap Done to try again.", true, true)
} else {
if (device.currentValue("multiStatus")?.contains("Sync")) { multiStatusEvent("Sync OK.", true, true) }
private multiStatusEvent(String statusValue, boolean force = false, boolean display = false) {
if (!device.currentValue(“multiStatus”)?.contains(“Sync”) || device.currentValue(“multiStatus”) == “Sync OK.” || force) {
sendEvent(name: “multiStatus”, value: statusValue, descriptionText: statusValue, displayed: display)
//event handlers related to configuration and sync
def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) {
def paramKey = parameterMap().find( {it.num == cmd.parameterNumber } ).key
logging(“Parameter {paramKey} value is {cmd.scaledConfigurationValue} expected " + state.”$paramKey".value, “info”)
state."$paramKey".state = (state."$paramKey".value == cmd.scaledConfigurationValue) ? “synced” : “incorrect”
syncNext()
def zwaveEvent(physicalgraph.zwave.commands.applicationstatusv1.ApplicationRejectedRequest cmd) {
logging(“rejected request!”,“warn”)
if ( state."$param.key"?.state == “inProgress” ) {
state."$param.key"?.state = “failed”
break
//event handlers
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
//ignore
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
logging("SwitchBinaryReport received, value: ${cmd.value} ",“info”)
sendEvent([name: “switch”, value: (cmd.value == 0 ) ? “off”: “on”])
Z-Wave Toolkit
def result =
logging(“Parsing: {description}")
if (description.startsWith("Err 106")) {
result = createEvent(
descriptionText: "Failed to complete the network security key exchange. If you are unable to receive data from it, you must remove it from your network and add it again.",
eventType: "ALERT",
value: "failed",
displayed: true,
} else if (description == "updated") {
return null
} else {
def cmd = zwave.parse(description, cmdVersions())
if (cmd) {
logging("Parsed: {cmd}”)
zwaveEvent(cmd)
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(cmdVersions())
if (encapsulatedCommand) {
logging(“Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}”)
zwaveEvent(encapsulatedCommand)
} else {
logging(“Unable to extract Secure command from $cmd”,“warn”)
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = cmdVersions()[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
logging(“Parsed Crc16Encap into: ${encapsulatedCommand}”)
} else {
logging(“Unable to extract CRC16 command from $cmd”,“warn”)
private logging(text, type = “debug”) {
if (settings.logging == “true” || type == “warn”) {
log."type" "{device.displayName} - $text"
private secEncap(physicalgraph.zwave.Command cmd) {
logging(“encapsulating command using Secure Encapsulation, command: $cmd”,“info”)
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(physicalgraph.zwave.Command cmd) {
logging(“encapsulating command using CRC16 Encapsulation, command: $cmd”,“info”)
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private encap(physicalgraph.zwave.Command cmd, Integer ep) {
encap(multiEncap(cmd, ep))
private encap(List encapList) {
encap(encapList[0], encapList[1])
private encap(Map encapMap) {
encap(encapMap.cmd, encapMap.ep)
private encap(physicalgraph.zwave.Command cmd) {
if (zwaveInfo.zw.contains(“s”)) {
secEncap(cmd)
} else if (zwaveInfo.cc.contains(“56”)){
crcEncap(cmd)
} else {
logging(“no encapsulation supported for command: $cmd”,“info”)
cmd.format()
private encapSequence(cmds, Integer delay=250) {
delayBetween(cmds.collect{ encap(it) }, delay)
private encapSequence(cmds, Integer delay, Integer ep) {
delayBetween(cmds.collect{ encap(it, ep) }, delay)
private List intToParam(Long value, Integer size = 1) {
def result =
size.times {
result = result.plus(0, (value & 0xFF) as Short)
value = (value >> 8)
return result
Device Configuration
private Map cmdVersions() {
[0x25: 1, 0x27: 1,0x20: 1,0x60: 3, 0x70: 2, 0x72: 1, 0x73: 1, 0x7A: 1, 0x85: 2,0x86: 1, 0x8E: 2]
private parameterMap() {[
[key: “allOnAllOff”, num: 1, size: 1, type: “enum”, options: [
255 : “ALL ON active, ALL OFF active.”,
0 : “ALL ON is not active ALL OFF is not active”,
1 : “ALL ON is not active ALL OFF active”,
2 : “ALL ON active ALL OFF is not active”
], def: “255”, title: “Activate / deactivate functions ALL ON / ALL OFF. D”,
desc: “”],
[key: “autoOffWithOverride”, size: 1, num: 3, type: “enum”, options: [
0 : “manual override disabled. After single button push the relay turns on and automatically turns off after specified time”,
1 : “manual override enabled. After single button push the relay turns on and automatically turns off after specified time. Another button push turns the relay off immediately”
], def: “0”, title: “Auto off relay after specified time, with the possibility of manual override”,
desc: “Auto off relay after specified time, with the possibility of manual override - immediate Off after button push.”],
[key: “autoOff”, size: 1, num: 4, type: “Integer”, def: 0, title: “Auto off”, desc: “(0,1 s – 6553,5 s) Time period for auto off, in miliseconds. 0 - Auto off disabled”],
[key: “commandsToControl”, size: 1, num: 6, type: “enum”, options: [
0 : “commands are sent when device is turned on and off”,
1 : “commands are sent when device is turned off. Enabling device does not send control commands. Double-clicking key sends ‘turn on’ command, dimmers memorize the last saved state (e.g. 50% brightness)”,
2 : “commands are sent when device is turned off”
], def: 0, title: “Sending commands to control”, desc: “Sending commands to control devices assigned to 1-st association group (key no. 1).”],
[key: “bistableKey”, num: 13, size: 1, type: “enum”, options: [
0: “[On / Off] device changes status on key status change”,
1: “Device status depends on key status: ON when the key is ON, OFF when the key is OFF”
], def: “0”, title: “Assigns bistable key status to the device status”,
descr: “Assigns bistable key status to the device statusl”],
[key: “switchType”, num: 14, size: 1, type: “enum”, options: [
0: “momentary switch”,
1: “toggle switch”
], def: “1”, title: “Switch type”,
descr: “Parameter defines as what type the device should treat the switch connected to the S1 terminal”],
[key: “restoreState”, num: 16, size: 1, type: “enum”, options: [
0: “power off after power failure”,
1: “restore state”
], def: “1”, title: “Restore state after power failure”,
descr: “This parameter determines if the device will return to state prior to the power failure after power is restored”],
But I’m not se when a/c its on or off because on my app there switch all the time its off. I’m not use any manual switch only app to setup my ac.
Anyone can help me please and one more thing when i tried change setup option 1 and save setup i have this messsage
