TonyLD
(Tony)
September 21, 2016, 1:14pm
1
Hi Guys
Does anyone know how often the fibaro eye reports its temperature to the hub?
TIA
TonyLD
einars
(EinarS)
September 21, 2016, 1:35pm
2
Think default is 60 minutes if changes in tmp.
TonyLD
(Tony)
September 21, 2016, 1:49pm
3
Hi thanks for your response, do you know if it can be reconfigured in ST, the configure button doesn’t respond on my app
einars
(EinarS)
September 21, 2016, 2:10pm
4
There is a couple og custom device that let you configure everything. Not at computer now so dont have the names.
einars
(EinarS)
September 21, 2016, 2:34pm
5
* Device Type Definition File
* Device Type: Fibaro Motion Sensor v3.2
* File Name: fibarMotion.groovy
* Initial Release: 2016-07-09
* Author: CSC
* Credit: SmartThings, Fibar Group S.A., Cyril Peponnet
* Copyright 2016 CSC
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
This file has been truncated. show original
This one should help you!
einars
(EinarS)
September 22, 2016, 1:14pm
6
@TonyLD had to check. factory settings and default device integrator is about 120 minutes if changes in tmp. But I always use a custom device handler. There you can test as often as you want (battery drain) Also have a look at what you can refresh on devices with the smart app pollister.
